TMP709-Q1 具有引脚可选迟滞功能并采用 SOT 封装的汽车类、可通过电阻器编程的温度开关
数据:
TMP709-Q1是一款完全集成的电阻可编程温度开关,温度阈值在整个工作范围内仅由一个外部电阻设置。 TMP709-Q1提供漏极开路,低电平有效输出,电源电压范围为2.7V至5.5V。
温度阈值精度通常为±0.5°C,最大值±3.5°C(60°C至100°C)。静态电流消耗通常为40μA。迟滞可通过引脚选择至2°C或10°C。
TMP709-Q1采用5引脚SOT-23封装。
特性
  • Qualified for Automotive Applications
  • AEC-Q100 Qualified With the Following Results:
    • Device Temperature Grade 1: –40°C to 125°C Ambient Operating Temperature Range
    • Device HBM ESD Classification Level 3A
    • Device CDM ESD Classification Level C6
  • Threshold Accuracy:
    • ±0.5°C Typical
    • ±3.5°C Maximum (60°C to 100°C)
  • Temperature Threshold Set By 1% External Resistor
  • Low Quiescent Current: 40 µA Typical
  • Open-Drain, Active-Low Output Stage
  • Pin-Selectable 2°C or 10°C Hysteresis
  • Reset Operation Specified at VCC = 0.8 V
  • Supply Range: 2.7 V to 5.5 V
  • Package: 5-Pin SOT-23
参数 与其它产品相比 温度开关
Operating Temperature Range (C)
Accuracy Over Temp Range (Max) (C)
Sensor Gain (mV/Deg C)
SetPoint Value (deg C)
SetPoint Type
Output Type
Supply Voltage (Min) (V)
Supply Voltage (Max) (V)
Supply Current (Typ) (uA)
Comparator Channels (#)
Features
Rating
Package Group
Package Size: mm2:W x L (PKG)
Interface
TMP709-Q1 LM26LV-Q1 LM57-Q1 TMP300-Q1 TMP708 TMP708-Q1 TMP709
0 to 125     -40 to 150     -50 to 125
-50 to 150
-50 to 160
-40 to 125     -40 to 125     0 to 125     -40 to 125
3     2.3     1.3     2     3     3     3
  -5.1 to -12.8     -5.2 to 12.9     10
0 to 125     Range (0 to 150)
130, 135
-40 to 160     -40 to 125     0 to 125     0 to 125     0 to 125
Resistor Programmable     Factory Programmed     Resistor Programmable     Resistor Programmable     Resistor Programmable     Resistor Programmable     Resistor Programmable
Open Drain     Open Drain
Push Pull
Open Drain
Push Pull
Open Drain     Open Drain     Open Drain     Open Drain
2.7     1.6     2.4     1.8     2.7     2.7     2.7
5.5     5.5     5.5     18     5.5     5.5     5.5
40     8     24     110     40     40     40
1     1     1     1     1     1     1
Hysteresis (2°C or 10°C)
Pin-Selectable Hysteresis
Built-in Hysteresis
Hysteresis (5°C)
Temperature Sensor and Switch
Trip Test
Built-in Hysteresis
Hysteresis (5°C or 10°C)
Trip Test
Hysteresis (10°C or 30°C)
Automotive     Automotive     Automotive     Automotive     Catalog     Automotive     Catalog
SOT-23     WSON     TSSOP     SC70     SOT-23     SOT-23     SOT-23
5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23)     See datasheet (WSON)     8TSSOP: 19 mm2: 6.4 x 3(TSSOP)     6SC70: 4 mm2: 2.1 x 2(SC70)     5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23)     5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23)     5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23)
Switch     Analog Output
Switch
Analog Output
Switch
Analog Output
Switch
Switch     Switch     Switch
方框图 (1)
技术文档
数据手册(1)
元器件购买 TMP709-Q1 相关库存
