LM57器件是一款具有模拟温度传感器输出的精密双路输出温度开关,适用于宽温度范围的工业级应用。跳变温度( T TRIP )可从-40°C至150°C温度范围内的256种可能值中进行选择.V TEMP 是AB类模拟电压输出,该电压输出与温度成正比,负温度系数(NTC)可编程。两个外部1%电阻设置T TRIP 和V TEMP 斜率。数字和模拟输出具有保护功能,并且可监视系统过热事件。
内置的热滞后功能(T HYST )可防止数字输出发生振荡.T OVER 和 T OVER 数字输出将在芯片温度超过T TRIP 时置为有效,在芯片温度低于T TRIP 与T HYST 的差值时置为无效。
T OVER 为高电平有效,并且采用推挽结构。 T OVER 为低电平有效,并且采用开漏结构。将T OVER 与TRIP-TEST相连,可在输出发生跳变后将其锁定。将TRIP-TEST强制为低电平可将输出清零。将TRIP-TEST驱动为高电平会将数字输出置为有效。处理器可检查T OVER 或< span style =“text-decoration:overline”> T OVER 的状态,从而确认它们是否已切换至激活状态。这样一来,便可以在系统装配后现场验证比较器和输出电路的功能。当TRIP-TEST为高电平时,V TEMP 引脚为跳变基准电压。系统随后可使用该电压计算LM57
所有商标均为各自所有者的财产。
Operating Temperature Range (C) |
Accuracy Over Temp Range (Max) (C) |
Sensor Gain (mV/Deg C) |
SetPoint Value (deg C) |
SetPoint Type |
Output Type |
Supply Voltage (Min) (V) |
Supply Voltage (Max) (V) |
Supply Current (Typ) (uA) |
Comparator Channels (#) |
Features |
Rating |
Package Group |
Package Size: mm2:W x L (PKG) |
Interface |
LM57 | LM26LV | LM56 | TMP300 | TMP708 | TMP709 |
-50 to 150 | 0 to 150 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
1.5 | 2.3 | 3 | 2 | 3 | 3 |
-5.2 to -12.9 | -5.1 to -12.8 | 6.2 | 10 | ||
-40 to 150 |
Range (0 to 150) 50, 60, 65, 70 75, 80, 85, 90 95, 100, 105, 110 115, 120, 125, 130 135, 140, 145, 150 |
-40 to 125 | -40 to 125 | 0 to 125 | 0 to 125 |
Resistor Programmable | Factory Programmed | Resistor Programmable | Resistor Programmable | Resistor Programmable | Resistor Programmable |
Open Drain Push Pull |
Open Drain | Open Drain | Open Drain | Open Drain |
2.4 | 1.6 | 2.7 | 1.8 | 2.7 | 2.7 |
5.5 | 5.5 | 10 | 18 | 5.5 | 5.5 |
24 | 8 | 230 | 110 | 40 | 40 |
1 | 1 | 2 | 1 | 1 | 1 |
Built-in Hysteresis Hysteresis (5°C or 10°C) Temperature Sensor and Switch Trip Test |
Built-in Hysteresis Hysteresis (5°C) Temperature Sensor and Switch Trip Test |
Built-in Hysteresis Hysteresis (5°C) Temperature Sensor and Switch |
Hysteresis (5°C or 10°C) Pin-Selectable Hysteresis Temperature Sensor and Switch |
Hysteresis (10°C or 30°C) Pin-Selectable Hysteresis |
Hysteresis (2°C or 10°C) Pin-Selectable Hysteresis |
Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
TSSOP WSON |
WSON |
SOIC VSSOP |
SC70 SOT-23 |
SOT-23 | SOT-23 |
8TSSOP: 19 mm2: 6.4 x 3(TSSOP) See datasheet (WSON) |
8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) |
6SC70: 4 mm2: 2.1 x 2(SC70) 6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) |
5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) |
Analog Output Switch |
Switch | Switch |
