TMP235 精密模拟输出温度传感器
数据:
TMP23x器件是精密CMOS集成电路线性模拟温度传感器系列,输出电压与温度成正比工程师可用于多种模拟温度传感应用。这些温度传感器比市场上类似的引脚兼容器件更精确,具有0°C至+ 70°C±0.5°C和±1°C的典型精度。该系列的增加精度适用于许多模拟温度传感应用。 TMP235器件在-40°C至+ 150°C的整个温度范围内提供10 mV /°C的正斜率输出,电源电压范围为2.3 V至5.5 V.较高增益的TMP236传感器提供19.5 mV的正斜率输出/°C,-10°C至+ 125°C,电源电压范围为3.1 V至5.5 V.
9μA典型静态电流和800μs典型上电时间可实现有效功率循环架构可最大限度地降低电池供电设备的功耗。 AB类输出驱动器提供强大的500μA最大输出,可驱动高达1000 pF的容性负载,并可直接连接到模数转换器采样和保持输入。 TMP23xanalog输出温度传感器具有极佳的精度和强大的线性输出驱动器,是无源热敏电阻的经济型替代品。
特性
  • Cost-Effective Alternative to Thermistors
  • Wide Temperature Measurement Range:
    • –40°C to +150°C (TMP235)
    • –10°C to +125°C (TMP236)
  • Available in Two Accuracy Level Variants:
    • A2 Level: ±0.5°C (Typical)
    • A4 Level: ±1°C (Typical)
  • Positive Slope Sensor Gain, Offset (Typical):
    • 10 mV/°C, 500 mV at 0°C (TMP235)
    • 19.5 mV/°C, 400 mV at 0°C (TMP236)
  • Wide Operating Supply Voltage Range:
    • 2.3 V to 5.5 V (TMP235)
    • 3.1 V to 5.5 V (TMP236)
  • Short Circuit Protected Output
  • Low Power: 9 µA (Typical)
  • Strong Output For Driving Loads up to 1000 pF
  • Available Package Options:
    • 5-Pin SC70 (DCK) Surface Mount
    • 3-Pin SOT-23 (DBZ) SurfaceMount
All trademarks are the property of their respective owners.
参数 与其它产品相比 模拟温度传感器
Local Sensor Accuracy (Max) (+/- C)
Operating Temperature Range (C)
Supply Voltage (Min) (V)
Supply Voltage (Max) (V)
Supply Current (Max) (uA)
Sensor Gain (mV/Deg C)
Rating
Features
Output Impedance (Ohm)
Interface
TMP235 LM135 LM135A LM20 LM235 LM335 LM35 LM50 LM60 LMT84 LMT85 LMT86 LMT87 LMT88 LMT89 TMP20
1     3     1     1.5     3     6     0.5     2     2     2.7     2.7     2.7     2.7     5     2.5     2.5
-40 to 150     -55 to 150     -55 to 150     -40 to 125
-55 to 130
-40 to 125     -40 to 100     -40 to 110
-55 to 150
0 to 100
0 to 70
-40 to 125     -25 to 125
-40 to 125
-50 to 150     -50 to 150     -50 to 150     -50 to 150     -55 to 130     -55 to 130     -55 to 125
2.3     5     5     2.4     5     5     4     4.5     2.7     1.5     1.8     2.2     2.7     2.4     2.4     1.8
5.5     3.01     2.99     5.5     3.01     3.04     30     10     10     5.5     5.5     5.5     5.5     5.5     5.5     5.5
12     400     400     7     400     400     114     130     110     8.1     8.1     8.1     8.1     7     7     4
10     10     10     -11.7     10     10     10     10     6.25     -5.5     -8.2     -10.9     -13.6     -11.77     -11.77     -11.77
Catalog     Catalog     Catalog     Catalog     Catalog     Catalog     Catalog     Catalog     Catalog     Catalog     Catalog     Catalog     Catalog     Catalog     Catalog     Catalog
Industry standard pinout         Industry standard pinout
UL Recognized
    UL Recognized     UL Recognized       Industry standard pinout     Industry standard pinout     Industry standard pinout     Industry standard pinout     Industry standard pinout     Industry standard pinout
20     0.5     0.5     160     0.5     0.6     0.4     2000     800             160     160     10
Analog output     Analog Output     Analog Output     Analog Output     Analog Output     Analog Output     Analog Output     Analog Output     Analog Output     Analog Output     Analog Output     Analog Output     Analog Output     Analog Output     Analog Output     Analog Output
方框图 (1)
技术文档
数据手册(1)
元器件购买 TMP235 相关库存
