数据: LM94022/-Q1 1.5-V, SC70, Multi-Gain Analog Temperature Sensor With Class-AB Output 数据表
LM94022 /-Q1器件是精密模拟输出CMOS集成电路温度传感器,具有可选的线性负温度系数(NTC)。 AB类输出结构为LM94022 /-Q1提供了强大的输出源和吸收电流能力,可驱动重载瞬态负载,例如采样保持模数转换器的输入。 LM94022 /-Q1的低5.4μA电源电流和1.5V工作电压使其成为电池供电系统以及一般温度检测应用的理想选择。
增益选择1(GS1)和增益选择0(GS0)逻辑输入为温度 - 电压输出传递函数选择四个增益之一:-5.5 mV /°C,-8.2 mV /°C,-10.9 mV /°C和-13.6 mV /C。选择-5.5 mV /°C(GS1和GS0均为低电平),LM94022 /-Q1可在低至-15°C至+ 150°C的整个温度范围内测量温度,同时工作电压低至1.5 V.当GS1和GS0都接高电平时,选择最高温度灵敏度-13.6 mV /°C。增益选择输入可以直接连接到V DD 或接地,无需任何上拉或下拉电阻,从而减少了元件数量和电路板面积。这些输入也可以由逻辑信号驱动,允许系统在操作或系统诊断期间优化增益。
Local Sensor Accuracy (Max) (+/- C) |
Operating Temperature Range (C) |
Supply Voltage (Min) (V) |
Supply Voltage (Max) (V) |
Supply Current (Max) (uA) |
Sensor Gain (mV/Deg C) |
Rating |
Features |
Output Impedance (Ohm) |
Interface |
LM94022 | LM20 | LM94021 | LM94023 | LMT84 |
1.5 | 1.5 | 1.5 | 1.5 | 2.7 |
-50 to 150 |
-40 to 125 -55 to 130 |
-50 to 150 | -50 to 150 | -50 to 150 |
1.5 | 2.4 | 1.5 | 1.5 | 1.5 |
5.5 | 5.5 | 5.5 | 5.5 | 5.5 |
8.1 | 7 | 12 | 8.1 | 8.1 |
-5.5 to -13.6 | -11.7 | -5.5 to -13.6 | -5.5 or -8.2 | -5.5 |
Catalog | Catalog | Catalog | Catalog | Catalog |
Selectable gain setting UL Recognized |
Industry standard pinout UL Recognized |
UL Recognized | Selectable gain setting | Industry standard pinout |
5.2 | 160 | 8 | 4.4 | |
Analog Output | Analog Output | Analog Output | Analog Output | Analog Output |
