数据: 1.5°C Accurate Programmable Digital Temp Sensor w/ SPI™ Interface 数据表
TMP122和TMP124是SPI兼容的温度传感器,采用SOT23-6和SO-8封装。 TMP122和TMP124温度传感器仅需一个上拉电阻即可实现完整功能,能够在40°C至+ 125°C的温度范围内测量2°C范围内的温度,工作温度高达150°C 。可编程分辨率,可编程设定点和关闭功能为各种应用提供了多种功能。低电源电流和2.7V至5.5V的电源电压使TMP122成为低功耗应用的理想选择。
TMP122和TMP124是各种通信中扩展热测量的理想选择,计算机,消费者,环境,工业和仪器仪表应用。
SPI是Motorola的注册商标。所有其他商标均为其各自所有者的财产。
Interface |
Local Sensor Accuracy (Max) (+/- C) |
Temp Resolution (Max) (bits) |
Operating Temperature Range (C) |
Supply Voltage (Min) (V) |
Supply Voltage (Max) (V) |
Supply Current (Typ) (uA) |
Supply Current (Max) (uA) |
Features |
Addresses |
Rating |
Package Group |
Package Size: mm2:W x L (PKG) |
Iq (Typ) (uA) |
TMP122 | TMP121 | TMP122-EP | TMP123 | TMP124 | TMP125 |
SPI, Microwire | SPI, Microwire | SPI, Microwire | SPI, Microwire | SPI, Microwire | SPI, Microwire |
1.5 | 1.5 | 1.5 | 1.5 | 1.5 | 2 |
12 | 12 | 12 | 12 | 12 | 12 |
-40 to 125 | -40 to 125 | -55 to 125 | -55 to 125 | -55 to 125 | -40 to 125 |
2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 |
5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 |
50 | 35 | 50 | 35 | 50 | 36 |
75 | 50 | 75 | 50 | 75 | 50 |
Configurable Resolution Programmable Alert Fault Queue Shutdown |
Shutdown |
Shutdown |
Shutdown |
NA | NA | NA | NA | NA | NA |
Catalog | Catalog | HiRel Enhanced Product | Catalog | Catalog | Catalog |
SOT-23 | SOT-23 | SOT-23 | SOT-23 | SOIC | SOT-23 |
6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) | 6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) |
