TMP100-Q1-Q1和TMP101-Q1是双线,串行输出温度传感器,采用SOT23-6封装。不要求外部组件,TMP100- Q1-Q1和TMP101-Q1读取温度的分辨力为0.0625°C。
TMP100-Q1-Q1和TMP101-Q1特有SMBus和I 2 C兼容接口, TMP100-Q1允许在一个总线连接上高达8器件.TMP101-Q1提供每设备高达3器件的SMBus报警功能。
TMP100-Q1和TMP101-Q1是在多种通信,计算机,用户,环境,工业和测量仪器应用中进行拓展温度测量的最佳选择。
TMP100-Q1和TMP101-Q1的规定工作温度范围为-40℃至125℃。
< /DIV>Interface |
Local Sensor Accuracy (Max) (+/- C) |
Temp Resolution (Max) (bits) |
Operating Temperature Range (C) |
Supply Voltage (Min) (V) |
Supply Voltage (Max) (V) |
Supply Current (Typ) (uA) |
Supply Current (Max) (uA) |
Features |
Addresses |
Rating |
Package Group |
Package Size: mm2:W x L (PKG) |
Iq (Typ) (uA) |
TMP101-Q1 | LM73-Q1 | TMP100-Q1 | TMP102-Q1 | TMP112-Q1 |
I2C, SMBus, 2-Wire | I2C, SMBus, 2-Wire | I2C, SMBus, 2-Wire | I2C, SMBus, 2-Wire | I2C, SMBus, 2-Wire |
2 | 1.45 | 2 | 3 | 0.5 |
12 | 14 | 12 | 12 | 12 |
-40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
2.7 | 2.7 | 2.7 | 1.4 | 1.4 |
5.5 | 5.5 | 5.5 | 3.6 | 3.6 |
45 | 320 | 45 | 3 | 7 |
75 | 550 | 75 | 10 | 10 |
Configurable Resolution Programmable Alert Fault Queue One-Shot Conversion Shutdown |
Configurable Resolution, Programmable Alert, One-Shot Conversion, Shutdown UL Recognized |
Configurable Resolution, One-Shot Conversion, Shutdown |
Programmable Alert Fault Queue One-Shot Conversion Shutdown NIST Traceable |
3 | 6 | 8 | 4 | 4 |
Automotive | Automotive | Automotive | Automotive | Automotive |
SOT-23 | SOT-23-THIN | SOT-23 | SOT-5X3 | SOT-5X3 |
6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 6SOT-23-THIN: 8 mm2: 2.8 x 2.9(SOT-23-THIN) | 6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 6SOT-5X3: 3 mm2: 1.6 x 1.6(SOT-5X3) | 6SOT-5X3: 3 mm2: 1.6 x 1.6(SOT-5X3) |
45 | 320 | 45 | 10 | 7 |
