数据: TMP10x Temperature Sensor With I2C and SMBus Interface with Alert Function in SOT-23 Package 数据表
TMP100和TMP101器件是数字温度传感器,适用于负温度系数(NTC)和正温度系数(PTC)热敏电阻更换。这些器件的典型精度为±1°C,无需校准或外部元件信号调理。设备温度传感器是高度线性的,不需要复杂的计算或查找表来获得温度。片上12位ADC的分辨率低至0.0625°C。这些器件采用6引脚SOT-23封装。
TMP100和TMP101器件具有SMBus,双线和I 2 C接口兼容性。 TMP100设备允许一条总线上最多八个设备。 TMP101器件提供SMBus报警功能,每条总线最多三个器件。
TMP100和TMP101器件是各种通信,计算机,消费类,环境,工业和仪器仪表应用中扩展温度测量的理想选择。
指定了TMP100和TMP101器件适用于-55°C至125°C的温度范围。
Interface |
Local Sensor Accuracy (Max) (+/- C) |
Temp Resolution (Max) (bits) |
Operating Temperature Range (C) |
Supply Voltage (Min) (V) |
Supply Voltage (Max) (V) |
Supply Current (Typ) (uA) |
Supply Current (Max) (uA) |
Features |
Addresses |
Rating |
Package Group |
Package Size: mm2:W x L (PKG) |
Iq (Typ) (uA) |
TMP101 | LM73 | TMP100 |
I2C, SMBus, 2-Wire | I2C, SMBus, 2-Wire | I2C, SMBus, 2-Wire |
2 | 1 | 2 |
12 | 14 | 12 |
-55 to 125 | -40 to 150 | -55 to 125 |
2.7 | 2.7 | 2.7 |
5.5 | 5.5 | 5.5 |
45 | 320 | 45 |
75 | 550 | 75 |
Configurable Resolution Programmable Alert Fault Queue One-Shot Conversion Shutdown |
Configurable Resolution Programmable Alert One-Shot Conversion Shutdown UL Recognized |
Configurable Resolution One-Shot Conversion Shutdown |
3 | 6 | 8 |
Catalog | Catalog | Catalog |
SOT-23 | SOT-23-THIN | SOT-23 |
6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 6SOT-23-THIN: 8 mm2: 2.8 x 2.9(SOT-23-THIN) | 6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) |
45 | 320 | 45 |
