数据: SNx4HC595 8-Bit Shift Registers With 3-State Output Registers 数据表
SNx4HC595器件包含一个8位,串行输入,并行输出移位寄存器,用于为8位D型存储寄存器供电。存储寄存器具有并行的3态输出。为移位寄存器和存储寄存器提供单独的时钟。移位寄存器具有直接覆盖清除(> SRCLR )输入,串行(SER)输入和用于级联的串行输出。当输出使能(> OE )输入为高电平时,输出处于高阻态。
所有其他商标均为其各自所有者的财产
Technology Family |
VCC (Min) (V) |
VCC (Max) (V) |
F @ Nom Voltage (Max) (Mhz) |
ICC @ Nom Voltage (Max) (mA) |
tpd @ Nom Voltage (Max) (ns) |
Input Type |
3-State Output |
IOL (Max) (mA) |
Output Type |
Rating |
Operating Temperature Range (C) |
Package Group |
Package Size: mm2:W x L (PKG) |
SN54HC595-SP |
HC |
2 |
6 |
28 |
0.08 |
34 |
CMOS |
Yes |
7.8 |
CMOS |
Space |
-55 to 125 |
CDIP CFP |
See datasheet (CDIP) See datasheet (CFP) |
无样片 |
