TLV246x是一系列低功耗轨到轨输入/输出运算放大器,专为便携式应用而设计。输入共模电压范围超出电源轨,可在低压系统中实现最大动态范围。放大器输出具有轨到轨性能和高输出驱动能力,解决了旧式轨到轨输入/输出运算放大器的一个局限性。这种轨到轨动态范围和高输出驱动使TLV246x成为缓冲模数转换器的理想选择。
运算放大器具有6.4 MHz的带宽和1.6 V /μs的压摆率500μA电源电流,提供良好的交流性能和低功耗。该系列的三个成员提供关断端子,将放大器置于超低电源电流模式(I DD =0.3μA/ch)。在关断期间,运算放大器输出处于高阻态。直流应用的输入噪声电压为11 nV / Hz,输入失调电压为100 μV。
该系列采用薄型SOT23,MSOP和TSSOP封装。 TLV2460是首款轨到轨输入/输出运算放大器,采用6引脚SOT23封装,非常适合高密度电路。该系列产品适用于扩展的温度范围(T A = ?? 40°C至125°C),适用于工业控制和汽车系统,以及军用温度范围(T ) A = ?? 55°C至125°C)用于军事系统。
Number of Channels (#) |
Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
GBW (Typ) (MHz) |
Slew Rate (Typ) (V/us) |
Rail-to-Rail |
Vos (Offset Voltage @ 25C) (Max) (mV) |
Iq per channel (Typ) (mA) |
Rating |
Operating Temperature Range (C) |
Package Group |
Output Current (Typ) (mA) |
Offset Drift (Typ) (uV/C) |
Vn at 1kHz (Typ) (nV/rtHz) |
Architecture |
IIB (Max) (pA) |
CMRR (Typ) (dB) |
Package Size: mm2:W x L (PKG) |
TLV2462M | TLV2442A-Q1 | TLV2460 | TLV2460M | TLV2461 | TLV2461-Q1 | TLV2461A-Q1 | TLV2461M | TLV2462 | TLV2462-Q1 | TLV2463 | TLV2463-Q1 | TLV2464 | TLV2465 |
2 | 2 | 1 | 1 | 1 | 1 | 1 | 1 | 2 | 2 | 2 | 2 | 4 | 4 |
2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 |
6 | 10 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 |
6.4 | 1.81 | 6.4 | 6.4 | 6.4 | 6.4 | 6.4 | 6.4 | 6.4 | 6.4 | 6.4 | 6.4 | 6.4 | 6.4 |
1.6 | 1.4 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 | 1.6 |
In Out | In to V- Out | In Out | In Out | In Out | In Out | In Out | In Out | In Out | In Out | In Out | In Out | In Out | In Out |
2 | 0.95 | 2 | 2 | 2 | 2 | 1.5 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
0.55 | 0.725 | 0.55 | 0.55 | 0.55 | 0.55 | 0.55 | 0.55 | 0.55 | 0.55 | 0.55 | 0.55 | 0.55 | 0.55 |
Military | Automotive | Catalog | Military | Catalog | Automotive | Automotive | Military | Catalog | Automotive | Catalog | Automotive | Catalog | Catalog |
-55 to 125 | -40 to 125 | -40 to 125 0 to 70 | -55 to 125 | -40 to 125 0 to 70 | -40 to 125 | -40 to 125 | -55 to 125 | -40 to 125 0 to 70 | -40 to 125 | -40 to 125 0 to 70 | -40 to 125 | -40 to 125 0 to 70 | -40 to 125 0 to 70 |
CFP | SOIC TSSOP | PDIP SOIC SOT-23 | CFP | PDIP SOIC SOT-23 | TSSOP | TSSOP | CFP | PDIP SOIC TSSOP VSSOP | SOIC TSSOP VSSOP | PDIP SOIC VSSOP | TSSOP | PDIP SOIC TSSOP | PDIP SOIC TSSOP |
80 | 15 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 |
2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 | 2 |
11 | 16 | 11 | 11 | 11 | 11 | 11 | 11 | 11 | 11 | 11 | 11 | 11 | 11 |
Bipolar | CMOS | Bipolar | Bipolar | Bipolar | Bipolar | Bipolar | Bipolar | Bipolar | Bipolar | Bipolar | Bipolar | Bipolar | Bipolar |
14000 | 60 | 14000 | 14000 | 14000 | 14000 | 14000 | 14000 | 14000 | 14000 | 14000 | 14000 | 14000 | 14000 |
85 | 75 | 85 | 85 | 85 | 85 | 85 | 85 | 85 | 85 | 85 | 85 | 85 | 85 |
See datasheet (CFP) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8TSSOP: 19 mm2: 6.4 x 3(TSSOP) | See datasheet (PDIP) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | See datasheet (CFP) | See datasheet (PDIP) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 8TSSOP: 19 mm2: 6.4 x 3(TSSOP) | 8TSSOP: 19 mm2: 6.4 x 3(TSSOP) | See datasheet (CFP) | See datasheet (PDIP) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8TSSOP: 19 mm2: 6.4 x 3(TSSOP) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8TSSOP: 19 mm2: 6.4 x 3(TSSOP) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | See datasheet (PDIP) 14SOIC: 52 mm2: 6 x 8.65(SOIC) 10VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) | See datasheet (PDIP) 14SOIC: 52 mm2: 6 x 8.65(SOIC) 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) | See datasheet (PDIP) 16SOIC: 59 mm2: 6 x 9.9(SOIC) 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) |
无样片 | 无样片 | 无样片 | 无样片 | 无样片 |
