THS4011和THS4012是高速,单/双电压反馈放大器,适用于各种应用。这些器件具有良好的交流性能,带宽为290 MHz,压摆率为310 V /μs,建立时间为37 ns(0.1%)。这些放大器具有110 mA的高输出驱动能力,每通道仅消耗7.8 mA电源电流。对于要求低失真的应用,THS4011 /4012在f = 1 MHz时的总谐波失真(THD)为-80 dBc。对于视频应用,THS4011 /4012提供0.1 dB增益平坦度至70 MHz,0.006%差分增益误差和0.01°差分相位误差。
Number of Channels (#) |
Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
GBW (Typ) (MHz) |
Slew Rate (Typ) (V/us) |
Rail-to-Rail |
Vos (Offset Voltage @ 25C) (Max) (mV) |
Iq per channel (Typ) (mA) |
Rating |
Operating Temperature Range (C) |
Package Group |
Output Current (Typ) (mA) |
Offset Drift (Typ) (uV/C) |
Vn at 1kHz (Typ) (nV/rtHz) |
Architecture |
IIB (Max) (pA) |
CMRR (Typ) (dB) |
Package Size: mm2:W x L (PKG) |
THS4011M |
1 |
10 |
30 |
290 |
310 |
No |
6 |
7.8 |
Military |
-55 to 125 |
CDIP LCCC |
110 |
15 |
7.5 |
Voltage FB Bipolar |
6000000 |
90 |
See datasheet (CDIP) 20LCCC: 79 mm2: 8.89 x 8.89(LCCC) |
无样片 |
