OPA365零交叉系列产品,轨道,高性能,CMOS运行放大器,优化后用于极低电压,单电源应用。轨到轨输入/输出,低噪音(4.5 nV /√ Hz )和高速操作(50-MHz增益带宽)是这款设备非常适合驱动取样模数转换器(ADC).OPA365支持音频,信号调节,传感器放大,国防,航空航天和医疗应用.OPA365还非常适合手机功率放大器控制环路的应用。
特性包括出色的共模抑制比(CMRR),无输入阶段交叉失真,输出共模范围包括负电源和正电源。输出电压摆幅在电轨的10mV之内。
< p> OPA365采用SOT23-5封装方式并具有-55°C至125°C的工作温度范围。
Number of Channels (#) |
Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
GBW (Typ) (MHz) |
Slew Rate (Typ) (V/us) |
Rail-to-Rail |
Vos (Offset Voltage @ 25C) (Max) (mV) |
Iq per channel (Typ) (mA) |
Rating |
Operating Temperature Range (C) |
Package Group |
Output Current (Typ) (mA) |
Offset Drift (Typ) (uV/C) |
Vn at 1kHz (Typ) (nV/rtHz) |
Architecture |
IIB (Max) (pA) |
CMRR (Typ) (dB) |
Package Size: mm2:W x L (PKG) |
OPA365-EP | OPA2365 | OPA2365-Q1 | OPA365 | OPA365-Q1 |
1 | 2 | 2 | 1 | 1 |
2.2 | 2.2 | 2.2 | 2.2 | 2.2 |
5.5 | 5.5 | 5.5 | 5.5 | 5.5 |
50 | 50 | 50 | 50 | 50 |
25 | 25 | 25 | 25 | 25 |
In Out | In Out | In Out | In Out | In Out |
0.2 | 0.2 | 0.2 | 0.2 | 0.2 |
4.6 | 4.6 | 4.6 | 4.6 | 4.6 |
HiRel Enhanced Product | Catalog | Automotive | Catalog | Automotive |
-55 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
SOT-23 | SOIC | SOIC | SOIC SOT-23 | SOT-23 |
65 | 65 | 65 | 65 | 65 |
3 | 1 | 1 | 1 | 1 |
4.5 | 4.5 | 4.5 | 4.5 | 4.5 |
Voltage FB CMOS | CMOS Voltage FB | CMOS Voltage FB | CMOS Voltage FB | CMOS Voltage FB |
10 | 10 | 10 | 10 | 10 |
120 | 120 | 120 | 120 | 120 |
5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) |
