此单反相器门设计用于1.65 V至5.5 VV CC 操作。
SN74LVC1G04执行布尔函数Y = A 。
NanoStar ??和NanoFree?封装技术是IC封装概念的一项重大突破,使用裸片作为封装。
该器件完全适用于使用I off 的部分断电应用。 I off 电路禁用输出,防止在断电时损坏通过器件的电流回流。
(1)自定义温度范围
Technology Family |
Sub-Family |
Gate Type |
VCC (Min) (V) |
VCC (Max) (V) |
Bits (#) |
Voltage (Nom) (V) |
F @ Nom Voltage (Max) (Mhz) |
ICC @ Nom Voltage (Max) (mA) |
tpd @ Nom Voltage (Max) (ns) |
IOL (Max) (mA) |
Input Type |
Output Type |
Logic |
3-State Output |
Schmitt Trigger |
Rating |
Operating Temperature Range (C) |
Package Group |
Package Size: mm2:W x L (PKG) |
SN74LVC1G04-EP | SN74LVC1G00 | SN74LVC1G02 | SN74LVC1G04 | SN74LVC1G04-Q1 | SN74LVC1G07 | SN74LVC1G07-EP | SN74LVC1G07-Q1 | SN74LVC1G08 | SN74LVC1G08-EP | SN74LVC1G08-Q1 | SN74LVC1G17 | SN74LVC1G17-EP | SN74LVC1G17-Q1 | SN74LVC1G32 | SN74LVC1G32-EP | SN74LVC1G32-Q1 | SN74LVC1G34 |
LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC | LVC |
Inverting Buffer/Driver | NAND Gate | NOR Gate | Inverting Buffer/Driver | Inverting Buffer/Driver | Non-Inverting Buffer/Driver | Non-Inverting Buffer/Driver | Non-Inverting Buffer/Driver | AND Gate | AND Gate | AND Gate | Non-Inverting Buffer/Driver | Non-Inverting Buffer/Driver | Non-Inverting Buffer/Driver | OR Gate | OR Gate | OR Gate | Non-Inverting Buffer/Driver |
INVERTER BUFFER | NAND | NOR | INVERTER BUFFER | INVERTER BUFFER | OPEN DRAIN BUFFER | OPEN DRAIN BUFFER | OPEN DRAIN BUFFER | AND | AND | AND | SCHMITT TRIGGER BUFFER | SCHMITT TRIGGER BUFFER | SCHMITT TRIGGER BUFFER | OR | OR | OR | BUFFER |
1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 | 1.65 |
5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 6.5 | 6.5 | 5.5 | 5.5 | 5.5 | 5.5 |
1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 | 1.8 2.5 3.3 5 |
150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 | 150 |
0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.01 | 0.02 | 0.01 | 0.01 | 0.025 | 0.001 |
13.9 8 5.7 4.5 | 9 5.5 4.7 4 | 8 5.5 4.5 4 | 7.5 5.2 4.2 3.7 | 7.5 5.2 4.2 3.7 | 8.6 6 4.7 4 | 5.7 4.9 | 9.8 7 5.7 4.9 | 4.5 6 4 5 | 8 5.5 4.5 4 | 8 5.5 4.5 4 | 11 6.5 5.5 5 | 11 6.5 5.5 5 | 14 9 8 7 | 7.2 4.4 3.6 3.4 | 8 6.5 5.7 4.5 | 11 7.5 6.5 6 | 8.6 4.4 4.1 3.2 |
32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 32 | 24 | 32 | 32 | 32 | 32 | 32 | 32 |
CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL | Schmitt-trigger CMOS/TTL | CMOS/TTL | Schmitt-trigger CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL | CMOS/TTL |
CMOS | CMOS | CMOS | CMOS | CMOS | CMOS Open-Drain | CMOS | CMOS Open-Drain | CMOS | CMOS | CMOS | CMOS | CMOS | CMOS | CMOS | CMOS | CMOS | CMOS |
Inverting | True | True | Inverting | Inverting | True | True | True | True | True | True | True | True | True | True | True | True | True |
No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No | No |
No | No | No | No | No | No | No | No | No | No | No | Yes | Yes | Yes | No | No | No | No |
HiRel Enhanced Product | Catalog | Catalog | Catalog | Automotive | Catalog | HiRel Enhanced Product | Automotive | Catalog | HiRel Enhanced Product | Automotive | Catalog | HiRel Enhanced Product | Automotive | Catalog | HiRel Enhanced Product | Automotive | Catalog |
-55 to 125 | -40 to 125 -40 to 85 | -40 to 125 -40 to 85 | -40 to 125 -40 to 85 | -40 to 125 | -40 to 125 -40 to 85 | -55 to 125 | -40 to 125 | -40 to 125 -40 to 85 | -40 to 85 -55 to 125 | -40 to 125 -40 to 85 | -40 to 125 -40 to 85 | -55 to 125 | -40 to 125 | -40 to 125 -40 to 85 | -40 to 85 -55 to 125 | -40 to 125 | -40 to 125 -40 to 85 |
SOT-23 | DSBGA SC70 SON SOT-23 SOT-5X3 X2SON | DSBGA SC70 SON SOT-23 SOT-5X3 X2SON | DSBGA SC70 SON SOT-23 SOT-5X3 X2SON | SC70 SOT-23 | DSBGA SC70 SON SOT-23 SOT-5X3 X2SON | SC70 | SC70 SOT-23 | DSBGA SC70 SON SOT-23 SOT-5X3 X2SON | SC70 SOT-23 | SC70 SOT-23 | DSBGA SC70 SON SOT-23 SOT-5X3 X2SON | SC70 SOT-23 | SC70 SOT-23 | DSBGA SC70 SON SOT-23 SOT-5X3 X2SON | SC70 SOT-23 | SC70 SOT-23 | DSBGA SC70 SON SOT-23 SOT-5X3 X2SON |
5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | See datasheet (DSBGA) 5SC70: 4 mm2: 2.1 x 2(SC70) See datasheet (SON) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 5SOT-5X3: 3 mm2: 1.6 x 1.6(SOT-5X3) 5X2SON: 1 mm2: .8 x .8(X2SON) | See datasheet (DSBGA) 5SC70: 4 mm2: 2.1 x 2(SC70) See datasheet (SON) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 5SOT-5X3: 3 mm2: 1.6 x 1.6(SOT-5X3) 5X2SON: 1 mm2: .8 x .8(X2SON) | See datasheet (DSBGA) 5SC70: 4 mm2: 2.1 x 2(SC70) See datasheet (SON) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 5SOT-5X3: 3 mm2: 1.6 x 1.6(SOT-5X3) 5X2SON: 1 mm2: .8 x .8(X2SON) | 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | See datasheet (DSBGA) 5SC70: 4 mm2: 2.1 x 2(SC70) See datasheet (SON) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 5SOT-5X3: 3 mm2: 1.6 x 1.6(SOT-5X3) 5X2SON: 1 mm2: .8 x .8(X2SON) | 5SC70: 4 mm2: 2.1 x 2(SC70) | 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | See datasheet (DSBGA) 5SC70: 4 mm2: 2.1 x 2(SC70) See datasheet (SON) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 5SOT-5X3: 3 mm2: 1.6 x 1.6(SOT-5X3) 5X2SON: 1 mm2: .8 x .8(X2SON) | 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | See datasheet (DSBGA) 5SC70: 4 mm2: 2.1 x 2(SC70) See datasheet (SON) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 5SOT-5X3: 3 mm2: 1.6 x 1.6(SOT-5X3) 5X2SON: 1 mm2: .8 x .8(X2SON) | 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | See datasheet (DSBGA) 5SC70: 4 mm2: 2.1 x 2(SC70) See datasheet (SON) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 5SOT-5X3: 3 mm2: 1.6 x 1.6(SOT-5X3) 5X2SON: 1 mm2: .8 x .8(X2SON) | 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | See datasheet (DSBGA) 5SC70: 4 mm2: 2.1 x 2(SC70) See datasheet (SON) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 5SOT-5X3: 3 mm2: 1.6 x 1.6(SOT-5X3) 5X2SON: 1 mm2: .8 x .8(X2SON) |
