数据: UCC28C4x-Q1 Automotive BiCMOS Low-Power Current-Mode PWM Controllers 数据表
UCC28C4x-Q1系列器件是高性能电流模式PWM控制器。它们是增强型BiCMOS版本,与行业标准UC28C4x系列PWM控制器具有引脚兼容性。
提供控制固定频率,峰值电流模式电源的必要功能,该系列具有多种性能优势。这些器件提供高达1 MHz的高频工作,启动和工作电流较低,从而最大限度地降低了启动损耗和低工作功耗,从而提高了效率。这些器件还具有快速电流输出,输出延迟时间为35 ns,具有±1 A峰值输出电流能力,可直接驱动大型外部MOSFET的上升和下降时间。
UCC28C4x-Q1系列是采用8引脚SOIC(D)封装。
所有商标均为其各自所有者的财产。
Topology |
Control Method |
Vin (Min) (V) |
Vin (Max) (V) |
Frequency (Max) (kHz) |
UVLO Thresholds On/Off (V) |
Duty Cycle (Max) (%) |
Gate Drive (Typ) (A) |
Features |
Rating |
Operating Temperature Range (C) |
Pin/Package |
UCC28C42-Q1 | UCC28C40-Q1 | UCC28C41-Q1 | UCC28C43-Q1 | UCC28C44-Q1 | UCC28C45-Q1 |
Boost Buck-Boost Flyback Forward | Boost Buck Buck-Boost Flyback Forward | Boost Buck-Boost Flyback Forward | Boost Buck Buck-Boost Flyback Forward | Boost Buck Buck-Boost Flyback Forward | Boost Buck Buck-Boost Flyback Forward |
Current | Current | Current | Current | Current | Current |
6.6 | 7 | 8.4 | 9 | 7.6 | |
20 | 20 | 20 | 20 | 20 | |
1000 | 1000 | 1000 | 1000 | 1000 | 1000 |
14.5/9 | 7/6.6 | 7/6.6 | 8.4/7.6 | 14.5/9 | 8.4/7.6 |
100 | 100 | 50 | 100 | 50 | 50 |
1 | 1 | 1 | 1 | 1 | 1 |
Adjustable Switching Frequency Current Limiting Dead Time Control Error Amplifier Multi-topology Programmable Max Duty Cycle | Adjustable Switching Frequency Current Limiting Dead Time Control Error Amplifier Programmable Max Duty Cycle | Error Amplifier | Error Amplifier | ||
Automotive | Automotive | Automotive | Automotive | Automotive | Automotive |
-40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
8SOIC | 8SOIC | 8SOIC | 8SOIC | 8SOIC | 8SOIC |
无样片 | 无样片 | 无样片 | 无样片 |
