SG2524和SG3524器件集成了在单芯片上构建调节电源,逆变器或开关稳压器所需的所有功能。它们还可以用作高功率输出应用的控制元件。 SG2524和SG3524设计用于采用固定频率,脉冲宽度调制(PWM)技术的任一极性开关稳压器,变压器耦合DC-DC转换器,无变压器倍压器和极性转换器应用。互补输出允许单端或推挽应用。每个器件都包括一个片内稳压器,误差放大器,可编程振荡器,脉冲转向触发器,两个未提交的传输晶体管,一个高增益比较器,以及限流和关断电路。
Topology |
Control Method |
Vin (Min) (V) |
Vin (Max) (V) |
Frequency (Max) (kHz) |
UVLO Thresholds On/Off (V) |
Duty Cycle (Max) (%) |
Gate Drive (Typ) (A) |
Features |
Rating |
Operating Temperature Range (C) |
Pin/Package |
SG3524 | SG2524 | TL494 | TL594 |
Boost Buck Flyback Forward Full-Bridge Half-Bridge Push-Pull | Boost Buck Flyback Forward Full-Bridge Half-Bridge Push-Pull | Boost Buck Flyback Forward Full-Bridge Half-Bridge Push-Pull | Boost Buck Flyback Forward Full-Bridge Half-Bridge Push-Pull |
Voltage | Voltage | Voltage | Voltage |
8 | 8 | -0.3 | -0.3 |
40 | 40 | 41 | 41 |
722 | 722 | 300 | 300 |
N/A | N/A | N/A | 6.1/6 |
45 | 45 | 45 | 45 |
0.05 | 0.05 | 0.2 | 0.2 |
Adjustable Switching Frequency Error Amplifier Multi-topology | Adjustable Switching Frequency Error Amplifier Multi-topology | Adjustable Switching Frequency Dead Time Control Error Amplifier Multi-topology | Adjustable Switching Frequency Dead Time Control Error Amplifier Multi-topology |
Catalog | Catalog | Catalog | Catalog |
0 to 70 | -25 to 85 | -40 to 85 0 to 70 | -40 to 85 0 to 70 |
16PDIP 16SO 16SOIC | 16PDIP 16SOIC | 16PDIP 16SO 16SOIC 16TSSOP | 16PDIP 16SO 16SOIC 16TSSOP |
