UCC3895是一个相移PWM控制器,通过相移一个半桥的开关来实现全桥功率级的控制。另一个。该器件允许恒定频率脉冲宽度调制和谐振零电压开关,以在高频率下提供高效率。该器件既可用作电压模式,也可用作电流模式控制器。
虽然UCC3895保持了UC3875 /6/7/8系列和UC3879的功能,但它还增加了该控制器系列的功能。增强控制逻辑,自适应延迟设置和关闭功能等功能。由于该器件采用BCDMOS工艺制造,因此其工作电源电流远低于双极性器件。 UCC3895的最大时钟频率为1 MHz。
Topology |
Control Method |
Vin (Min) (V) |
Vin (Max) (V) |
Frequency (Max) (kHz) |
UVLO Thresholds On/Off (V) |
Duty Cycle (Max) (%) |
Gate Drive (Typ) (A) |
Features |
Rating |
Operating Temperature Range (C) |
Pin/Package |
UCC3895 | LM5046 | UCC2895 | UCC28950 |
Phase-Shifted Full-Bridge | Phase-Shifted Full-Bridge | Phase-Shifted Full-Bridge | Phase-Shifted Full-Bridge |
Current Feedforward Voltage | Current Voltage | Current Feedforward Voltage | Current Voltage |
11 | 14 | 11 | 7.3 |
17 | 105 | 17 | 20 |
1000 | 2000 | 1000 | 1000 |
11/9 | Programmable/1.25V | 11/9 | 7.3/6.75 |
100 | 50 | 100 | 95 |
0.1 | 1.5 2 | 0.1 | 0.2 |
Adjustable Switching Frequency Current Limiting Error Amplifier Multi-topology Soft Start Soft Switching Synchronization Pin | Adjustable Switching Frequency Current Limiting Error Amplifier HV Start-up Soft Start Soft Switching | Adjustable Switching Frequency Current Limiting Error Amplifier Multi-topology Soft Start Soft Switching Synchronization Pin | Adjustable Switching Frequency Current Limiting Error Amplifier Light Load Efficiency Multi-topology Soft Start Soft Switching Synchronization Pin |
Catalog | Catalog | Catalog | Catalog |
0 to 70 | -40 to 125 | -40 to 85 | -40 to 125 |
20PDIP 20SOIC 20TSSOP | 28HTSSOP 28WQFN | 20PDIP 20SOIC 20TSSOP | 24TSSOP |
