LM5025B是LM5025有源钳位PWM控制器的功能变体。 LM5025B的功能差异如下:
LM5025B PWM控制器包含使用有源钳位/复位技术实现电源转换器所需的所有功能。采用有源钳位技术,与传统的捕获绕组或RDC钳位/复位技术相比,可以实现更高的效率和更高的功率密度。提供两个控制输出,主电源开关控制(OUT_A)和有源钳位开关控制(OUT_B)。两个内部复合栅极驱动器与MOS和双极器件并联,提供卓越的栅极驱动特性。该控制器专为高速运行而设计,包括振荡器频率范围高达1MHz,总PWM和电流检测传播延迟小于100ns。
LM5025B包括一个高压启动稳压器,可在13V至100V的宽输入范围内工作。其他功能包括:线路欠压锁定(UVLO),软启动,振荡器UP /DOWN同步功能,精密基准和热关断。
所有商标均为其各自所有者的财产。
Topology |
Control Method |
Vin (Min) (V) |
Vin (Max) (V) |
Frequency (Max) (kHz) |
UVLO Thresholds On/Off (V) |
Duty Cycle (Max) (%) |
Gate Drive (Typ) (A) |
Features |
Rating |
Operating Temperature Range (C) |
Pin/Package |
LM5025B | LM5025 | LM5025A | LM5025C |
Active-Clamp Forward Forward | Active-Clamp Forward Forward | Active-Clamp Forward Forward | Active-Clamp Forward Forward |
Feedforward Voltage | Feedforward Voltage | Feedforward Voltage | Feedforward Voltage |
13 | 13 | 13 | 13 |
100 | 90 | 90 | 90 |
1000 | 1000 | 1000 | 1000 |
Programmable/2.5V | Programmable/2.5V | Programmable/2.5V | Programmable/2.5V |
73 | 80 | 80 | 91 |
3 | 3 | 3 | 3 |
Current Limiting HV Start-up Leading Edge Blanking Soft Start Thermal Shutdown | Current Limiting HV Start-up Leading Edge Blanking Soft Start Thermal Shutdown | Current Limiting HV Start-up Leading Edge Blanking Soft Start Thermal Shutdown | Current Limiting HV Start-up Leading Edge Blanking Soft Start Thermal Shutdown |
Catalog | Catalog | Catalog | Catalog |
-40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
16TSSOP 16WSON | 16TSSOP 16WSON | 16TSSOP 16WSON | 16TSSOP |
