数据: LM5035B PWM Controller w/Integ Half-Bridge and SyncFET Drivers 数据表
LM5035B半桥控制器/栅极驱动器包含使用带线电压馈电的电压模式控制实现半桥拓扑功率转换器所需的所有功能 - 前锋。
LM5035B是LM5035A半桥PWM控制器的功能变体。与LM5035A或LM5035相比,LM5035B具有更高的最大占空比和更高的启动稳压器输出电流。此外,LM5035B的同步整流器驱动输出在关断模式下保持低电平。
LM5035,LM5035A和LM5035B包括一个浮动高侧栅极驱动器,能够在高达105V的电源电压下工作。高侧和低侧栅极驱动器都能够达到2A峰值。内置高压启动稳压器,以及可编程线路欠压锁定(UVLO)和过压保护(OVP)。振荡器采用单个电阻编程,频率高达2MHz。振荡器也可以与外部时钟同步。电流检测输入和可编程定时器提供逐周期电流限制和可调节打嗝模式过载保护.LM5035,LM5035A,LM5035B和LM5035C之间的差异总结如下。
所有商标均为其各自所有者的财产。
Topology |
Control Method |
Vin (Min) (V) |
Vin (Max) (V) |
Frequency (Max) (kHz) |
UVLO Thresholds On/Off (V) |
Duty Cycle (Max) (%) |
Gate Drive (Typ) (A) |
Features |
Rating |
Operating Temperature Range (C) |
Pin/Package |
LM5035B | LM5035C | LM5036 | LM5039 | UCC28250 | UCC28251 |
Half-Bridge | Half-Bridge Push-Pull | Full-Bridge Half-Bridge Push-Pull | Full-Bridge Half-Bridge Push-Pull | Forward Full-Bridge Half-Bridge Push-Pull | Forward Full-Bridge Half-Bridge Push-Pull |
Feedforward Voltage | Feedforward Voltage | Feedforward Voltage | Voltage | Current Voltage | Current Feedforward Voltage |
13 | 13 | 18 | 13 | 4.3 | 4.3 |
105 | 105 | 100 | 105 | 20 | 20 |
2000 | 2000 | 2000 | 2000 | 1000 | 1000 |
Programmable/1.25V | Programmable/1.25V | Programmable/1.25V | Programmable/1.25V | 4.3/4.1 | 4.3/4.1 |
50 | 50 | 50 | 50 | 100 | 100 |
2 | 2 | 2 | 2 | 0.2 | 0.2 |
Multi-topology Synchronization Pin | Synchronization Pin | Current Limiting Frequency Synchronization HV Start-up Input Line Monitor Integrated Switch Leading Edge Blanking Multi-topology Soft Start Synchronization Pin Thermal Shutdown Wide DC input | Multi-topology Synchronization Pin | HV Start-up | Leading Edge Blanking Multi-topology Programmable Slope Compensation Soft Start Synchronization Pin |
Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
-40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
20HTSSOP 24WQFN | 20HTSSOP 24WQFN | 28WQFN | 20HTSSOP 24WQFN | 20QFN 20TSSOP | 20QFN 20TSSOP |
