TLC272 双路单电源运算放大器
数据:
The TLC272 and TLC277 precision dual operational amplifiers combine a wide range of input offset voltage grades with low offset voltage drift, high input impedance, low noise, and speeds approaching those of general-purpose BiFET devices.
These devices use Texas Instruments silicon-gate LinCMOS™ technology, which provides offset voltage stability far exceeding the stability available with conventional metal-gate processes.
The extremely high input impedance, low bias currents, and high slew rates make these cost-effective devices ideal for applications previously reserved for BiFET and NFET products. Four offset voltage grades are available (C-suffix and I-suffix types), ranging from the low-cost TLC272 (10 mV) to the high-precision TLC277 (500 uV). These advantages, in combination with good common-mode rejection and supply voltage rejection, make these devices a good choice for new state-of-the-art designs as well as for upgrading existing designs.
In general, many features associated with bipolar technology are available on LinCMOS™ operational amplifiers without the power penalties of bipolar technology. General applications such as transducer interfacing, analog calculations, amplifier blocks, active filters, and signal buffering are easily designed with the TLC272 and TLC277. The devices also exhibit low voltage single-supply operation, making them ideally suited for remote and inaccessible battery-powered applications. The common-mode input voltage range includes the negative rail.
A wide range of packaging options is available, including small-outline and chip carrier versions for high-density system applications.
The device inputs and outputs are designed to withstand –100-mA surge currents without sustaining latch-up.
The TLC272 and TLC277 incorporate internal ESD-protection circuits that prevent functional failures at voltages up to 2000 V as tested under MIL-STD-883C, Method 3015.2; however, care should be exercised in handling these devices as exposure to ESD may result in the degradation of the device parametric performance.
The C-suffix devices are characterized for operation from 0°C to 70°C. The I-suffix devices are characterized for operation from –40°C to 85°C. The M-suffix devices are characterized for operation over the full military temperature range of –55°C to 125°C.
特性
  • 修整偏移电压:
    TLC277。 。 。在25°C时500 uV Max,V DD = 5 V
  • 输入偏移电压漂移...通常为0.1 uV /月,包括前30天
  • < li>特定温度范围内的宽范围电源电压:
    0°C至70°C ... 3 V至16 V
    ?? 40°C至85°C ... 4 V至16 V
    ?? 55°C至125°C ... 4 V至16 V
  • 单电源供电
  • 共模输入电压范围延伸至负电压轨以下( C-Suffix,I-Suffix类型)
  • 低噪声...通常为25 nV / Hz,f = 1 kHz
  • 输出电压范围包括负轨
  • 高输入阻抗... 10 12 Typ
  • ESD保护电路
  • 小型封装选项也可在磁带中使用和Reel
  • 设计闩锁免疫
LinCMOS是德州仪器的商标。 < /p>
参数 与其它产品相比 通用 运算放大器
Number of Channels (#)
Total Supply Voltage (Min) (+5V=5, +/-5V=10)
Total Supply Voltage (Max) (+5V=5, +/-5V=10)
GBW (Typ) (MHz)
Slew Rate (Typ) (V/us)
Rail-to-Rail
Vos (Offset Voltage @ 25C) (Max) (mV)
Iq per channel (Typ) (mA)
Vn at 1kHz (Typ) (nV/rtHz)
Rating
Operating Temperature Range (C)
Package Group
Package Size: mm2:W x L (PKG)
Offset Drift (Typ) (uV/C)
Features
Input Bias Current (Max) (pA)
CMRR (Typ) (dB)
Output Current (Typ) (mA)
Architecture
TLC272 TLC271 TLC274
2     1     4
3     3     3
16     16     16
0.32     0.32     0.32
3.6     3.6     3.6
In to V-     In to V-     In to V-
10     10     10
0.7     0.675     0.675
25     25     25
Catalog     Catalog     Catalog
-40 to 85
0 to 70
-40 to 85
-55 to 125
0 to 70
-40 to 85
-55 to 125
0 to 70
PDIP
SO
SOIC
TSSOP
PDIP
SO
SOIC
TSSOP
PDIP
SO
SOIC
SSOP
TSSOP
See datasheet (PDIP)
8SO: 48 mm2: 7.8 x 6.2(SO)
8SOIC: 29 mm2: 6 x 4.9(SOIC)
8TSSOP: 19 mm2: 6.4 x 3(TSSOP)
14SO: 80 mm2: 7.8 x 10.2(SO)
14SOIC: 52 mm2: 6 x 8.65(SOIC)
14SSOP: 48 mm2: 7.8 x 6.2(SSOP)
14TSSOP: 32 mm2: 6.4 x 5(TSSOP)
1.8     1.8     1.8
N/A     Shutdown     N/A
60     60     60
80     80     80
10     10     10
CMOS     CMOS     CMOS
技术文档
数据手册(1)
元器件购买 TLC272 相关库存
