NE5534,NE5534A,SA5534和SA5534A器件是高性能运算放大器,具有出色的直流和交流特性。其中一些功能包括极低的噪声,高输出驱动能力,高单位增益和最大输出摆幅带宽,低失真和高压摆率。
这些运算放大器在内部进行补偿增益等于或大于三。通过在COMP和COMP /BAL之间使用外部补偿电容,可以获得各种应用的频率响应优化。这些器件具有输入保护二极管,输出短路保护和偏移电压归零功能,可使用BALANCE和COMP /BAL引脚。
对于NE5534A和SA5534A器件,指定了最大限制等效输入噪声电压。
Number of Channels (#) |
Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
GBW (Typ) (MHz) |
Slew Rate (Typ) (V/us) |
Rail-to-Rail |
Vos (Offset Voltage @ 25C) (Max) (mV) |
Iq per channel (Typ) (mA) |
Vn at 1kHz (Typ) (nV/rtHz) |
Rating |
Operating Temperature Range (C) |
Package Group |
Package Size: mm2:W x L (PKG) |
Offset Drift (Typ) (uV/C) |
Features |
Input Bias Current (Max) (pA) |
CMRR (Typ) (dB) |
Output Current (Typ) (mA) |
Architecture |
SA5534A | NE5534 | NE5534A |
1 | 1 | 1 |
10 | 10 | 10 |
30 | 30 | 30 |
10 | 10 | 10 |
13 | 13 | 13 |
No | No | No |
4 | 4 | 4 |
4 | 4 | 4 |
3.5 | 4 | 3.5 |
Catalog | Catalog | Catalog |
-40 to 85 | 0 to 70 | 0 to 70 |
PDIP SOIC | PDIP SOIC | PDIP SOIC |
See datasheet (PDIP) 8SOIC: 29 mm2: 6 x 4.9(SOIC) | See datasheet (PDIP) 8SOIC: 29 mm2: 6 x 4.9(SOIC) | See datasheet (PDIP) 8SOIC: 29 mm2: 6 x 4.9(SOIC) |
0 | 0 | 0 |
N/A | Decompensated | Decompensated |
1500000 | 1500000 | 1500000 |
100 | 100 | 100 |
38 | 38 | 38 |
Bipolar | Bipolar | Bipolar |
