数据: LMV721, LMV722 10-MHz Low-Noise Low-Voltage Low-Power Operational Amplifier 数据表
LMV721(单通道)和LMV722(双通道)是低噪声低压低功耗运算放大器,可广泛应用于各种应用。 LMV721和LMV722的单位增益带宽为10 MHz,压摆率为5 V /μs,2.2 V时的静态电流为930μA/放大器。
LMV721和LMV722设计用于在低压和低噪声系统中提供最佳性能。它们提供轨到轨输出摆动到重载。输入共模电压范围包括接地,器件的最大输入失调电压为3.5 mV(超过建议的温度范围)。它们的容性负载能力在低电源电压下也很好。工作范围为2.2 V至5.5 V.
Number of Channels (#) |
Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
GBW (Typ) (MHz) |
Slew Rate (Typ) (V/us) |
Rail-to-Rail |
Vos (Offset Voltage @ 25C) (Max) (mV) |
Iq per channel (Typ) (mA) |
Vn at 1kHz (Typ) (nV/rtHz) |
Rating |
Operating Temperature Range (C) |
Package Group |
Package Size: mm2:W x L (PKG) |
Offset Drift (Typ) (uV/C) |
Features |
Input Bias Current (Max) (pA) |
CMRR (Typ) (dB) |
Output Current (Typ) (mA) |
Architecture |
LMV721 | LMV722 | LMV722-Q1 |
1 | 2 | 2 |
2.2 | 2.2 | 2.2 |
5 | 5 | 5 |
10 | 10 | 10 |
5.25 | 5.25 | 4.9 |
In to V- Out | In to V- Out | In to V- Out |
3 | 3 | 3 |
1.03 | 1.03 | 1.8 |
8.5 | 8.5 | 8.5 |
Catalog | Catalog | Automotive |
-40 to 105 | -40 to 105 | -40 to 125 |
SC70 SOT-23 | SOIC VSSOP | VSSOP |
5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) |
0.6 | 0.6 | 0.6 |
Small Size | N/A | N/A |
400000 | 400000 | 260000 |
89 | 89 | 88 |
24 | 24 | 15 |
Bipolar | Bipolar | Bipolar |
