LMV321,LMV358,LMV324和LMV324S器件是单通道,双通道和四通道低压(2.7 V至5.5 V)运算放大器,带有轨道 - 铁路输出摆动。对于需要低压操作,节省空间和低成本的应用,这些器件是最具成本效益的解决方案。这些放大器专为低压(2.7 V至5 V)工作而设计,其性能指标达到或超过LM358和LM324器件,工作电压范围为5 V至30 V.封装尺寸仅为LED的一半。 DBV(SOT-23)封装,这些器件可用于各种应用。
Number of Channels (#) |
Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
GBW (Typ) (MHz) |
Slew Rate (Typ) (V/us) |
Rail-to-Rail |
Vos (Offset Voltage @ 25C) (Max) (mV) |
Iq per channel (Typ) (mA) |
Vn at 1kHz (Typ) (nV/rtHz) |
Rating |
Operating Temperature Range (C) |
Package Group |
Package Size: mm2:W x L (PKG) |
Offset Drift (Typ) (uV/C) |
Features |
Input Bias Current (Max) (pA) |
CMRR (Typ) (dB) |
Output Current (Typ) (mA) |
Architecture |
LMV358 | LMV321 | LMV324 | LMV358A |
2 | 1 | 4 | 2 |
2.7 | 2.7 | 2.7 | 1.8 |
5.5 | 5.5 | 5.5 | 5.5 |
1 | 1 | 1 | 1 |
1 | 1 | 1 | 1.7 |
In to V- Out | In to V- Out | In to V- Out | In to V- Out |
7 | 7 | 7 | 4 |
0.105 | 0.13 | 0.102 | 0.08 |
39 | 39 | 39 | 33 |
Catalog | Catalog | Catalog | Catalog |
-40 to 125 | -40 to 125 -40 to 85 | -40 to 125 | -40 to 125 |
SOIC TSSOP VSSOP VSSOP | SC70 SOT-23 | SOIC TSSOP | SOIC VSSOP |
8SOIC: 29 mm2: 6 x 4.9(SOIC) 8TSSOP: 19 mm2: 6.4 x 3(TSSOP) 8VSSOP: 6 mm2: 3.1 x 2(VSSOP) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 14SOIC: 52 mm2: 6 x 8.65(SOIC) 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) |
5 | 5 | 5 | 1 |
Small Size | Small Size | N/A | Cost Optimized EMI Hardened |
250000 | 250000 | 250000 | |
65 | 65 | 65 | 95 |
60 | 60 | 60 | 40 |
Bipolar | Bipolar | Bipolar | CMOS |
