TLV9061(单通道),TLV9062(双通道)和TLV9064(四通道)是单路,双路和四路低压(1.8V至5.5 V)运算放大器,具有轨至轨输入和输出摆幅能力。适用于需要低工作电压,小型封装尺寸和高容性负载驱动能力的应用。虽然TLV906x的容性负载驱动能力为100pF,但电阻式开环输出阻抗便于在更高的容性负载下更轻松地实现稳定。此类运算放大器专为低工作电压(1.8V至5.5V)而设计,性能规格类似于OPAx316和TLVx316器件。
TLV906x系列有助于简化系统设计,因为该系列具有稳定的单位增益,集成了RFI和EMI抑制滤波器,而且在过驱条件下不会出现反相。
针对所有通道型号(单通道,双通道和四通道)提供微型封装(如SOT-553和WSON,)以及行业标准封装(如SOIC,MSOP,SOT-23和TSSOP)。
所有商标均为其各自所有者的财产。
Number of Channels (#) |
Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
GBW (Typ) (MHz) |
Slew Rate (Typ) (V/us) |
Rail-to-Rail |
Vos (Offset Voltage @ 25C) (Max) (mV) |
Iq per channel (Typ) (mA) |
Vn at 1kHz (Typ) (nV/rtHz) |
Rating |
Operating Temperature Range (C) |
Package Group |
Package Size: mm2:W x L (PKG) |
Offset Drift (Typ) (uV/C) |
Features |
Input Bias Current (Max) (pA) |
CMRR (Typ) (dB) |
Output Current (Typ) (mA) |
Architecture |
TLV9062 | OPA316 | TLV2316 | TLV2316-Q1 | TLV316 | TLV4316 | TLV6741 | TLV9061 | TLV9064 |
2 | 1 | 2 | 2 | 1 | 4 | 1 | 1 | 4 |
1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 1.8 | 2.25 | 1.8 | 1.8 |
5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 |
10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 |
6.5 | 6 | 6 | 6 | 6 | 6 | 4.75 | 6.5 | 6.5 |
In Out | In Out | In Out | In Out | In Out | In Out | Out | In Out | In Out |
1.6 | 2.5 | 3 | 3 | 3 | 3 | 1 | 1.5 | 1.6 |
0.538 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.85 | 0.538 | 0.538 |
16 | 11 | 12 | 12 | 12 | 12 | 5 | 16 | 16 |
Catalog | Catalog | Catalog | Automotive | Catalog | Catalog | Catalog | Catalog | Catalog |
-40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
SOIC TSSOP VSSOP WSON | SC70 SOT-23 | SOIC VSSOP | VSSOP | SC70 SOT-23 | SOIC TSSOP | SC70 | X2SON | SOIC TSSOP |
8SOIC: 29 mm2: 6 x 4.9(SOIC) 8TSSOP: 19 mm2: 6.4 x 3(TSSOP) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) See datasheet (WSON) | 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 14SOIC: 52 mm2: 6 x 8.65(SOIC) 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) | 5SC70: 4 mm2: 2.1 x 2(SC70) | 5X2SON: 1 mm2: .8 x .8(X2SON) | 14SOIC: 52 mm2: 6 x 8.65(SOIC) 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) |
0.53 | 2 | 2 | 2 | 2 | 2 | 0.35 | 0.3 | 0.53 |
Cost Optimized EMI Hardened Small Size | Small Size EMI Hardened | Cost Optimized EMI Hardened | Cost Optimized EMI Hardened | Cost Optimized EMI Hardened Small Size | Cost Optimized EMI Hardened | Cost Optimized EMI Hardened Small Size | Cost Optimized EMI Hardened Small Size | Cost Optimized EMI Hardened |
15 | ||||||||
103 | 80 | 90 | 90 | 90 | 90 | 130 | 103 | 103 |
50 | 50 | 50 | 50 | 50 | 50 | 50 | 50 | 50 |
CMOS | CMOS | CMOS | CMOS | CMOS | CMOS | CMOS | CMOS | CMOS |
金额:¥0.44690
去购买金额:¥5.05160
去购买型号:TS2278A(MSOP-8) 封装:MSOP8_3X3MM
品牌:Trusignal 描述:10MHz 轨到轨 10V/us Iq=1.1mA(per amp) Vos=5mV(Max) 双通道 产品性能媲美TI的TLV9062和LMV722、ST的TSV912、MicroChip的MCP6292、ADI的AD8692等
金额:¥
去购买
