TLV9061(单通道),TLV9062(双通道)和TLV9064(四通道)是单路,双路和四路低压(1.8V至5.5 V)运算放大器,具有轨至轨输入和输出摆幅能力。适用于需要低工作电压,小型封装尺寸和高容性负载驱动能力的应用。虽然TLV906x的容性负载驱动能力为100pF,但电阻式开环输出阻抗便于在更高的容性负载下更轻松地实现稳定。此类运算放大器专为低工作电压(1.8V至5.5V)而设计,性能规格类似于OPAx316和TLVx316器件。
TLV906x系列有助于简化系统设计,因为该系列具有稳定的单位增益,集成了RFI和EMI抑制滤波器,而且在过驱条件下不会出现反相。
针对所有通道型号(单通道,双通道和四通道)提供微型封装(如SOT-553和WSON,)以及行业标准封装(如SOIC,MSOP,SOT-23和TSSOP)。
所有商标均为其各自所有者的财产。
Number of Channels (#) |
Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
GBW (Typ) (MHz) |
Slew Rate (Typ) (V/us) |
Rail-to-Rail |
Vos (Offset Voltage @ 25C) (Max) (mV) |
Iq per channel (Typ) (mA) |
Vn at 1kHz (Typ) (nV/rtHz) |
Rating |
Operating Temperature Range (C) |
Package Group |
Package Size: mm2:W x L (PKG) |
Offset Drift (Typ) (uV/C) |
Features |
Input Bias Current (Max) (pA) |
CMRR (Typ) (dB) |
Output Current (Typ) (mA) |
Architecture |
TLV9061 | LM7341 | LM741 | OPA316 | TLV171 | TLV316 | TLV9062 |
1 | 1 | 1 | 1 | 1 | 1 | 2 |
1.8 | 2.7 | 10 | 1.8 | 4.5 | 1.8 | 1.8 |
5.5 | 32 | 44 | 5.5 | 36 | 5.5 | 5.5 |
10 | 4.6 | 1 | 10 | 3 | 10 | 10 |
6.5 | 1.9 | 0.5 | 6 | 1.5 | 6 | 6.5 |
In Out | In Out | In Out | Out | In Out | In Out | |
1.5 | 4 | 3 | 2.5 | 2.7 | 3 | 1.6 |
0.538 | 0.7 | 1.7 | 0.4 | 0.525 | 0.4 | 0.538 |
16 | 31 | 30 | 11 | 16 | 12 | 16 |
Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
-40 to 125 | -40 to 125 | -40 to 85 0 to 70 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
X2SON | SOT-23 | PDIP | SC70 SOT-23 | SOIC SOT-23 | SC70 SOT-23 | SOIC TSSOP VSSOP WSON |
5X2SON: 1 mm2: .8 x .8(X2SON) | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | See datasheet (PDIP) | 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SC70: 4 mm2: 2.1 x 2(SC70) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8TSSOP: 19 mm2: 6.4 x 3(TSSOP) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) See datasheet (WSON) |
0.3 | 2 | 15 | 2 | 1 | 2 | 0.53 |
Cost Optimized EMI Hardened Small Size | N/A | N/A | Small Size EMI Hardened | Cost Optimized EMI Hardened High Cload Drive | Cost Optimized EMI Hardened Small Size | Cost Optimized EMI Hardened Small Size |
250000 | 210000 | 15 | ||||
103 | 100 | 90 | 80 | 105 | 90 | 103 |
50 | 10 | 25 | 50 | 30 | 50 | 50 |
CMOS | Bipolar | Bipolar | CMOS | CMOS | CMOS | CMOS |
