TL06x系列的JFET输入运算放大器设计为TL08x系列放大器的低功耗版本。它们具有高输入阻抗,宽带宽,高压摆率,低输入失调和输入偏置电流。 TL06x系列具有与TL07x和TL08x系列相同的端子分配。
Number of Channels (#) |
Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
GBW (Typ) (MHz) |
Slew Rate (Typ) (V/us) |
Rail-to-Rail |
Vos (Offset Voltage @ 25C) (Max) (mV) |
Iq per channel (Typ) (mA) |
Vn at 1kHz (Typ) (nV/rtHz) |
Rating |
Operating Temperature Range (C) |
Package Group |
Package Size: mm2:W x L (PKG) |
Offset Drift (Typ) (uV/C) |
Features |
Input Bias Current (Max) (pA) |
CMRR (Typ) (dB) |
Output Current (Typ) (mA) |
Architecture |
TL064 | TL061 | TL061A | TL061B | TL062 | TL062A | TL062B | TL064A | TL064B |
4 | 1 | 1 | 1 | 2 | 2 | 2 | 4 | 4 |
7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 |
36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 | 36 |
1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 |
In to V+ | In to V+ | In to V+ | In to V+ | In to V+ | In to V+ | In to V+ | In to V+ | In to V+ |
15 | 6 | 6 | 3 | 15 | 6 | 3 | 6 | 3 |
0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 | 0.2 |
42 | 42 | 42 | 42 | 42 | 42 | 42 | 42 | 42 |
Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
-40 to 85 0 to 70 | -40 to 85 0 to 70 | 0 to 70 | 0 to 70 | -40 to 85 0 to 70 | 0 to 70 | 0 to 70 | 0 to 70 | 0 to 70 |
PDIP SO SOIC TSSOP | PDIP SO SOIC | PDIP SOIC | PDIP | PDIP SO SOIC TSSOP | PDIP SO SOIC | PDIP SOIC | PDIP SOIC | PDIP SOIC |
See datasheet (PDIP) 14SO: 80 mm2: 7.8 x 10.2(SO) 14SOIC: 52 mm2: 6 x 8.65(SOIC) 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) | See datasheet (PDIP) 8SO: 48 mm2: 7.8 x 6.2(SO) 8SOIC: 29 mm2: 6 x 4.9(SOIC) | See datasheet (PDIP) 8SOIC: 29 mm2: 6 x 4.9(SOIC) | See datasheet (PDIP) | See datasheet (PDIP) 8SO: 48 mm2: 7.8 x 6.2(SO) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8TSSOP: 19 mm2: 6.4 x 3(TSSOP) | See datasheet (PDIP) 8SO: 48 mm2: 7.8 x 6.2(SO) 8SOIC: 29 mm2: 6 x 4.9(SOIC) | See datasheet (PDIP) 8SOIC: 29 mm2: 6 x 4.9(SOIC) | See datasheet (PDIP) 14SOIC: 52 mm2: 6 x 8.65(SOIC) | See datasheet (PDIP) 14SOIC: 52 mm2: 6 x 8.65(SOIC) |
10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 | 10 |
Standard Amps | Standard Amps | Standard Amps | Standard Amps | Standard Amps | Standard Amps | Standard Amps | Standard Amps | Standard Amps |
200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 | 200 |
86 | 86 | 86 | 86 | 86 | 86 | 86 | 86 | 86 |
FET | FET | FET | FET | FET | FET | FET | FET | FET |
无样片 |
