NE5532,NE5532A,SA5532和SA5532A器件是高性能运算放大器,具有出色的直流和交流特性。它们具有极低噪声,高输出驱动能力,高单位增益和最大输出摆幅带宽,低失真,高压摆率,输入保护二极管和输出短路保护。这些运算放大器在内部进行补偿,以实现单位增益操作。这些器件规定了等效输入噪声电压的最大限值。
Number of Channels (#) |
Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
GBW (Typ) (MHz) |
Slew Rate (Typ) (V/us) |
Rail-to-Rail |
Vos (Offset Voltage @ 25C) (Max) (mV) |
Iq per channel (Typ) (mA) |
Vn at 1kHz (Typ) (nV/rtHz) |
Features |
THD + N @ 1 kHz (Typ) (%) |
Rating |
Operating Temperature Range (C) |
Package Group |
Output Current (Typ) (mA) |
Package Size: mm2:W x L (PKG) |
Architecture |
CMRR (Typ) (dB) |
Input Bias Current (Max) (pA) |
NE5532A | NE5532 | NE5534 | NE5534A | SA5532 |
2 | 2 | 1 | 1 | 2 |
10 | 10 | 10 | 10 | 10 |
30 | 30 | 30 | 30 | 30 |
9 | 9 | 13 | 13 | 9 |
No | No | No | No | No |
4 | 4 | 4 | 4 | 4 |
4 | 4 | 4 | 4 | 4 |
5 | 5 | 4 | 3.5 | 5 |
N/A | N/A | Decompensated | Decompensated | N/A |
0.002 | 0.002 | 0.002 | 0.002 | |
Catalog | Catalog | Catalog | Catalog | Catalog |
0 to 70 | 0 to 70 | 0 to 70 | 0 to 70 | -40 to 85 |
PDIP SO SOIC | PDIP SO SOIC | PDIP SOIC | PDIP SOIC | PDIP SOIC |
38 | 38 | 38 | 38 | 38 |
See datasheet (PDIP) 8SO: 48 mm2: 7.8 x 6.2(SO) 8SOIC: 29 mm2: 6 x 4.9(SOIC) | See datasheet (PDIP) 8SO: 48 mm2: 7.8 x 6.2(SO) 8SOIC: 29 mm2: 6 x 4.9(SOIC) | See datasheet (PDIP) 8SOIC: 29 mm2: 6 x 4.9(SOIC) | See datasheet (PDIP) 8SOIC: 29 mm2: 6 x 4.9(SOIC) | See datasheet (PDIP) 8SOIC: 29 mm2: 6 x 4.9(SOIC) |
Bipolar | Bipolar | Bipolar | Bipolar | Bipolar |
100 | 100 | 100 | 100 | 100 |
800000 | 800000 | 1500000 | 1500000 | 800000 |
