数据: THS413x High-Speed, Low-Noise, Fully-Differential I/O Amplifiers 数据表
THS413x器件是使用德州仪器(Texas Instruments)制造的全差分输入/差分输出器件系列中的一款器件。最先进的BiComI互补双极性工艺。
THS413x由输入到输出的真正全差分信号路径组成。这种设计可以实现出色的共模噪声抑制和改善的总谐波失真。
所有其他商标均为其各自所有者的财产
Architecture |
Number of Channels (#) |
Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
BW @ Acl (MHz) |
Acl, min spec gain (V/V) |
Slew Rate (Typ) (V/us) |
Vn at Flatband (Typ) (nV/rtHz) |
Vn at 1kHz (Typ) (nV/rtHz) |
Iq per channel (Typ) (mA) |
Vos (Offset Voltage @ 25C) (Max) (mV) |
Rail-to-Rail |
Features |
Rating |
Operating Temperature Range (C) |
Package Group |
Package Size: mm2:W x L (PKG) |
CMRR (Typ) (dB) |
Input Bias Current (Max) (pA) |
Offset Drift (Typ) (uV/C) |
GBW (Typ) (MHz) |
Output Current (Typ) (mA) |
2nd Harmonic (dBc) |
3rd Harmonic (dBc) |
@ MHz |
THS4130 | THS4131 | THS4140 | THS4141 | THS4150 | THS4151 |
Fully Differential Voltage FB | Fully Differential Voltage FB | Fully Differential Voltage FB | Fully Differential Voltage FB | Fully Differential Voltage FB | Fully Differential Voltage FB |
1 | 1 | 1 | 1 | 1 | 1 |
4 | 4 | 4 | 4 | 4 | 4 |
33 | 33 | 33 | 33 | 33 | 33 |
150 | 150 | 160 | 160 | 150 | 150 |
52 | 52 | 450 | 450 | 650 | 650 |
1.3 | 1.3 | 6.5 | 6.5 | 7.6 | 7.6 |
1.5 | 1.5 | 6.7 | 6.7 | 8 | 8 |
12.3 | 12.3 | 13.2 | 13.2 | 17.5 | 17.5 |
2 | 2 | 7 | 7 | 7 | 7 |
No | No | No | No | No | No |
Shutdown | N/A | Shutdown | N/A | Shutdown | N/A |
Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
-40 to 85 0 to 70 | -40 to 85 0 to 70 | -40 to 85 0 to 70 | -40 to 85 0 to 70 | -40 to 85 0 to 70 | -40 to 85 0 to 70 |
MSOP-PowerPAD SOIC VSSOP | MSOP-PowerPAD SOIC VSSOP | MSOP-PowerPAD SOIC VSSOP | MSOP-PowerPAD SOIC VSSOP | MSOP-PowerPAD SOIC | MSOP-PowerPAD SOIC VSSOP |
8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) 8SOIC: 29 mm2: 6 x 4.9(SOIC) | 8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) |
95 | 95 | 84 | 84 | 83 | 83 |
6000000 | 6000000 | 15000000 | 15000000 | 15000000 | 15000000 |
4.5 | 4.5 | 7 | 7 | 7 | 7 |
170 | 170 | 170 | 170 | 150 | 150 |
85 | 85 | 85 | 85 | 85 | 85 |
88 | 88 | 83 | 83 | 85 | 85 |
84 | 84 | 80 | 80 | 88 | 88 |
