THS4503 高速全差动放大器
数据:
THS4502和THS4503是德州仪器(TI)的高性能全差分放大器。具有省电功能的THS4502和无断电功能的THS4503为全差分放大器设定了新的性能标准,具有无与伦比的线性度,支持40 MHz的14位操作。封装选项包括8引脚SOIC和带PowerPAD的8引脚MSOP,可实现更小的占位面积,增强的交流性能和更高的散热能力。
特性
  • 全差分架构
  • 带宽:370 MHz
  • 压摆率:2800 V /μs< /li>
  • IMD 3 :30 MHz时为-95 dBc
  • OIP 3 :30 MHz时51 dBm
  • 输出共模控制
  • 宽电源电压范围:5 V,±5 V,12 V,15 V
  • 中心输入共模范围
  • 断电功能(THS4502)
  • 评估模块可用
参数 与其它产品相比 高速 运算放大器 (GBW>=50MHz)
Architecture
Number of Channels (#)
Total Supply Voltage (Min) (+5V=5, +/-5V=10)
Total Supply Voltage (Max) (+5V=5, +/-5V=10)
BW @ Acl (MHz)
Acl, min spec gain (V/V)
Slew Rate (Typ) (V/us)
Vn at Flatband (Typ) (nV/rtHz)
Vn at 1kHz (Typ) (nV/rtHz)
Iq per channel (Typ) (mA)
Vos (Offset Voltage @ 25C) (Max) (mV)
Rail-to-Rail
Features
Rating
Operating Temperature Range (C)
Package Group
Package Size: mm2:W x L (PKG)
CMRR (Typ) (dB)
Input Bias Current (Max) (pA)
Offset Drift (Typ) (uV/C)
GBW (Typ) (MHz)
Output Current (Typ) (mA)
2nd Harmonic (dBc)
3rd Harmonic (dBc)
@ MHz
THS4503 THS4500 THS4501 THS4502 THS4504 THS4505
Fully Differential     Fully Differential     Fully Differential     Fully Differential     Fully Differential     Fully Differential
1     1     1     1     1     1
4.5     4.5     4.5     4.5     4.5     4.5
15     15     15     15     15     15
370     370     370     370     260     260
1     1     1     1     1     1
2800     2800     2800     2800     1800     1800
6.8     7     7     6.8     8     8
27     27     27     27     21     21
23     23     23     23     16     16
4     7     7     4     7     7
No     In to V-     In to V-     No     In to V-     In to V-
N/A     Shutdown     N/A     Shutdown     Shutdown     N/A
Catalog     Catalog     Catalog     Catalog     Catalog     Catalog
0 to 70
-40 to 85
-40 to 85
0 to 70
-40 to 85
0 to 70
-40 to 85
0 to 70
-40 to 85     -40 to 85
MSOP-PowerPAD
SOIC
VSSOP
MSOP-PowerPAD
SOIC
VSSOP
MSOP-PowerPAD
SOIC
VSSOP
MSOP-PowerPAD
SOIC
VSSOP
MSOP-PowerPAD
SOIC
VSSOP
MSOP-PowerPAD
SOIC
VSSOP
8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD)
8SOIC: 29 mm2: 6 x 4.9(SOIC)
8VSSOP: 15 mm2: 4.9 x 3(VSSOP)
80     80     80     80     80     80
4600000     4600000     4600000     4600000     4600000     4600000
10     10     10     10     10     10
300     300     300     300     210     210
120     120     120     120     130     130
83     82     82     83     79     79
97     97     97     97     93     93
8     8     8     8     8     8
方框图 (1)
