THS4500和THS4501是德州仪器(TI)的高性能全差分放大器。具有省电功能的THS4500和无断电功能的THS4501为全差分放大器设定了新的性能标准,具有无与伦比的线性度,支持40 MHz的14位操作。封装选项包括SOIC-8和带PowerPAD的MSOP-8,占用空间更小,交流性能更强,散热能力更强。
Architecture |
Number of Channels (#) |
Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
BW @ Acl (MHz) |
Acl, min spec gain (V/V) |
Slew Rate (Typ) (V/us) |
Vn at Flatband (Typ) (nV/rtHz) |
Vn at 1kHz (Typ) (nV/rtHz) |
Iq per channel (Typ) (mA) |
Vos (Offset Voltage @ 25C) (Max) (mV) |
Rail-to-Rail |
Features |
Rating |
Operating Temperature Range (C) |
Package Group |
Package Size: mm2:W x L (PKG) |
CMRR (Typ) (dB) |
Input Bias Current (Max) (pA) |
Offset Drift (Typ) (uV/C) |
GBW (Typ) (MHz) |
Output Current (Typ) (mA) |
2nd Harmonic (dBc) |
3rd Harmonic (dBc) |
@ MHz |
THS4501 | THS4500 | THS4502 | THS4503 | THS4504 | THS4505 |
Fully Differential | Fully Differential | Fully Differential | Fully Differential | Fully Differential | Fully Differential |
1 | 1 | 1 | 1 | 1 | 1 |
4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 |
15 | 15 | 15 | 15 | 15 | 15 |
370 | 370 | 370 | 370 | 260 | 260 |
2800 | 2800 | 2800 | 2800 | 1800 | 1800 |
7 | 7 | 6.8 | 6.8 | 8 | 8 |
27 | 27 | 27 | 27 | 21 | 21 |
23 | 23 | 23 | 23 | 16 | 16 |
7 | 7 | 4 | 4 | 7 | 7 |
In to V- | In to V- | No | No | In to V- | In to V- |
N/A | Shutdown | Shutdown | N/A | Shutdown | N/A |
Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
-40 to 85 0 to 70 | -40 to 85 0 to 70 | -40 to 85 0 to 70 | 0 to 70 -40 to 85 | -40 to 85 | -40 to 85 |
MSOP-PowerPAD SOIC VSSOP | MSOP-PowerPAD SOIC VSSOP | MSOP-PowerPAD SOIC VSSOP | MSOP-PowerPAD SOIC VSSOP | MSOP-PowerPAD SOIC VSSOP | MSOP-PowerPAD SOIC VSSOP |
8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) |
80 | 80 | 80 | 80 | 80 | 80 |
4600000 | 4600000 | 4600000 | 4600000 | 4600000 | 4600000 |
10 | 10 | 10 | 10 | 10 | 10 |
300 | 300 | 300 | 300 | 210 | 210 |
120 | 120 | 120 | 120 | 130 | 130 |
82 | 82 | 83 | 83 | 79 | 79 |
97 | 97 | 97 | 97 | 93 | 93 |
8 | 8 | 8 | 8 | 8 | 8 |
