数据: Low-Distortion High-Speed Rail-to-Rail Output Operational Amplifiers 数据表
THS4222系列是一组轨到轨输出单,双和三低电压,高输出摆幅,低失真高高速放大器非常适合驱动数据转换器,视频切换或低失真应用。该系列电压反馈放大器可在单个15 V电源下工作,直至单个3 V电源,每个通道仅消耗14 mA的静态电流。此外,该系列还具有出色的交流性能,带宽为230 MHz,压摆率为975 V /μs,谐波失真(THD)在5 MHz时为90 dBc。
Architecture |
Number of Channels (#) |
Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
BW @ Acl (MHz) |
Acl, min spec gain (V/V) |
Slew Rate (Typ) (V/us) |
Vn at Flatband (Typ) (nV/rtHz) |
Vn at 1kHz (Typ) (nV/rtHz) |
Iq per channel (Typ) (mA) |
Vos (Offset Voltage @ 25C) (Max) (mV) |
Rail-to-Rail |
Features |
Rating |
Operating Temperature Range (C) |
Package Group |
Package Size: mm2:W x L (PKG) |
CMRR (Typ) (dB) |
Input Bias Current (Max) (pA) |
Offset Drift (Typ) (uV/C) |
GBW (Typ) (MHz) |
Output Current (Typ) (mA) |
2nd Harmonic (dBc) |
3rd Harmonic (dBc) |
@ MHz |
THS4225 | THS4226 |
Bipolar Voltage FB | Bipolar Voltage FB |
1 | 2 |
2.7 | 2.7 |
15 | 15 |
230 | 230 |
1 | 1 |
990 | 990 |
13 | 13 |
13 | 13 |
14 | 14 |
10 | 10 |
No | No |
Shutdown | Shutdown |
Catalog | Catalog |
-40 to 85 | -40 to 85 |
MSOP-PowerPAD SOIC VSSOP | MSOP-PowerPAD |
8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 10MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) |
94 | 94 |
3000000 | 3000000 |
20 | 20 |
230 | 230 |
100 | 100 |
92 | 92 |
96 | 96 |
1 | 1 |
