LMH6702 1.7 GHz、超低失真、宽带运算放大器
数据:
LMH6702是一款超宽带,直流耦合单片运算放大器,专为需要出色信号保真度的宽动态范围系统而设计。 LMH6702受益于电流反馈架构,无需外部补偿即可以极高的速度提供单位增益稳定性。
带宽为720 MHz(A V = 2 V /V, V O = 2 V PP ),通过60 MHz(R L =100Ω)的10位失真电平,1.83-nV /√ Hz 输入参考噪声和12.5 mA电源电流,LMH6702是高速闪存AD和DA转换器的理想驱动器或缓冲器。
宽动态范围系统,如雷达和通信接收器,需要宽带放大器,提供出色的信号纯度,LMH6702的低输入参考噪声和低谐波和互调失真是一种极具吸引力的高速解决方案。
LMH6702采用VIP10™互补双极工艺和成熟的电流反馈架构。 LMH6702采用SOIC和SOT-23封装。
特性
    V S =±5 V,T A = 25°C,A V = 2V /V,R L =100Ω,
    V OUT = 2 V PP ,典型的除非注明:
  • 2 nd 和3 rd 谐波(5 MHz,SOT-23)-100 /-96
    dBc
  • -3-dB带宽(V OUT = 0.5 V PP )1.7 GHz
  • 低噪声1.83 nV /√ Hz
  • 快速建立至0.1%13.4 ns
  • 快速摆率3100 V /μs
  • 供应电流12.5 mA
  • 输出电流80 mA
  • 低互调失真(75 MHz)-67 dBc
  • 改进CLC409和CLC449的更换
参数 与其它产品相比 高速 运算放大器 (GBW>=50MHz)
Architecture
Number of Channels (#)
Total Supply Voltage (Min) (+5V=5, +/-5V=10)
Total Supply Voltage (Max) (+5V=5, +/-5V=10)
BW @ Acl (MHz)
Acl, min spec gain (V/V)
Slew Rate (Typ) (V/us)
Vn at Flatband (Typ) (nV/rtHz)
Vn at 1kHz (Typ) (nV/rtHz)
Iq per channel (Typ) (mA)
Vos (Offset Voltage @ 25C) (Max) (mV)
Rail-to-Rail
Features
Rating
Operating Temperature Range (C)
Package Group
Package Size: mm2:W x L (PKG)
CMRR (Typ) (dB)
Input Bias Current (Max) (pA)
Offset Drift (Typ) (uV/C)
GBW (Typ) (MHz)
Output Current (Typ) (mA)
2nd Harmonic (dBc)
3rd Harmonic (dBc)
@ MHz
LMH6702 OPA2691 OPA2695 OPA3691 OPA3695 OPA691 OPA694 OPA695
Bipolar
Current FB
Bipolar
Current FB
Bipolar
Current FB
Bipolar
Current FB
Bipolar
Current FB
Bipolar
Current FB
Bipolar
Current FB
Bipolar
Current FB
1     2     2     3     3     1     1     1
8     4     3.5     4     3.5     4     7     5
12     12     12     12     12     12     12.6     12
1700     280     1100     280     1000     280     1500     1700
1     1     1     1     2     1     1     1
3100     2100     2900     2100     2400     2100     1700     4300
1.83     1.7     1.8     1.7     1.8     1.7     2.1     1.8
12.5     5.1     12.9     5.1     12.9     5.1     5.8     12.9
4.5     3     3.5     3     3.5     2.5     3     3
No     No     No     No     No     No     No     No
N/A     Shutdown     Small Size
Shutdown
Shutdown     Shutdown     Shutdown     N/A     Shutdown
Catalog     Catalog     Catalog     Catalog     Catalog     Catalog     Catalog     Catalog
-40 to 85     -40 to 85     -40 to 85     -40 to 85     -40 to 85     -40 to 85     -40 to 85     -40 to 85
SOIC
SOT-23
SOIC
SOIC
SOIC
VQFN
SOIC
SSOP
SSOP     SOIC
SOT-23
SOIC
SOT-23
SOIC
SOT-23
VSSOP
8SOIC: 29 mm2: 6 x 4.9(SOIC)
5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23)
14SOIC: 52 mm2: 6 x 8.65(SOIC)
16VQFN: 9 mm2: 3 x 3(VQFN)
16SOIC: 59 mm2: 6 x 9.9(SOIC)
16SSOP: 29 mm2: 6 x 4.9(SSOP)
16SSOP: 29 mm2: 6 x 4.9(SSOP)     8SOIC: 29 mm2: 6 x 4.9(SOIC)
6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23)
8VSSOP: 15 mm2: 4.9 x 3(VSSOP)
48     56     56     56     56     56     60     56
15000000     35000000     30000000     35000000     30000000     35000000     20000000     30000000
13     20     15     20     15     20     15     15
80     190     120     190     120     190     80     120
100     70     73     70     65     70     68     65
96     74     82     74     86     74     72     86
5     5     10     5     10     5     5     10
方框图 (2)
技术文档
数据手册(1)
元器件购买 LMH6702 相关库存
相关阅读
