数据: LMH6723/LMH6724 Single/Dual/Quad 370-MHz, 1-mA Current Feedback Operational Amplifier 数据表
LMH6723 /LMH6724提供260 MHz的小信号带宽,增益为+2 V /V,压摆率为600 V /μs,仅耗电1来自±5V电源的mA。
LMH6723 /LMH6724支持视频应用,具有0.03%和0.11°差分增益和相位,适用于NTSC和PAL视频信号,同时还提供0.1 dB至100的平坦增益响应兆赫。此外,LMH6723 /LMH6724可提供110 mA的线性输出电流。这种性能水平以及4.5至12V的宽电源范围使LMH6723 /LMH6724成为各种便携式应用的理想运算放大器。 LMH6723 /LMH6724采用小型封装(SOIC和SOT-23),低功耗和高性能,适用于各种便携式应用。
LMH6723 /LMH6724采用德州仪器(TI)制造。 VIP10免费双极过程。
Architecture |
Number of Channels (#) |
Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
BW @ Acl (MHz) |
Acl, min spec gain (V/V) |
Slew Rate (Typ) (V/us) |
Vn at Flatband (Typ) (nV/rtHz) |
Vn at 1kHz (Typ) (nV/rtHz) |
Iq per channel (Typ) (mA) |
Vos (Offset Voltage @ 25C) (Max) (mV) |
Rail-to-Rail |
Features |
Rating |
Operating Temperature Range (C) |
Package Group |
Package Size: mm2:W x L (PKG) |
CMRR (Typ) (dB) |
Input Bias Current (Max) (pA) |
Offset Drift (Typ) (uV/C) |
GBW (Typ) (MHz) |
Output Current (Typ) (mA) |
2nd Harmonic (dBc) |
3rd Harmonic (dBc) |
@ MHz |
LMH6724 |
Bipolar Current FB |
2 |
5 |
12 |
370 |
1 |
600 |
4.3 |
4.3 |
1 |
3 |
No |
N/A |
Catalog |
-40 to 85 |
SOIC |
8SOIC: 29 mm2: 6 x 4.9(SOIC) |
60 |
4000000 |
0 |
370 |
110 |
65 |
63 |
5 |
