LMH6714 /LMH6720 /LMH6722系列将德州仪器的VIP10高速互补双极性工艺与德州仪器的电流反馈拓扑结合在一起,可生成超高速运算放大器。这些放大器提供400MHz的小信号带宽,增益为+ 2V /V,压摆率为1800V /μs,而±5V电源仅消耗5.6mA。
LMH6714 /LMH6720 /LMH6722系列提供出色的视频在驱动背端75Ω负载时,NTSC和PAL视频信号具有0.01%和0.01°的差分增益和相位误差。它们还提供0.1dB至120MHz的平坦增益响应。此外,它们还可提供70mA的连续输出电流。这种性能水平使其成为广播级视频系统的理想运算放大器。
LMH6714 /LMH6720 /LMH6722的小型封装(SOIC,SOT-23和WSON),低功耗要求,低噪声和失真允许LMH6714 /LMH6720 /LMH6722用于便携式RF应用。关断期间的高阻态使LMH6720适用于将多个高速信号复用到共用传输线上。 LMH6720也是便携式应用的理想选择,可通过关断功能降低电流消耗。
所有商标均为其各自所有者的财产。
Architecture |
Number of Channels (#) |
Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
BW @ Acl (MHz) |
Acl, min spec gain (V/V) |
Slew Rate (Typ) (V/us) |
Vn at Flatband (Typ) (nV/rtHz) |
Vn at 1kHz (Typ) (nV/rtHz) |
Iq per channel (Typ) (mA) |
Vos (Offset Voltage @ 25C) (Max) (mV) |
Rail-to-Rail |
Features |
Rating |
Operating Temperature Range (C) |
Package Group |
Package Size: mm2:W x L (PKG) |
CMRR (Typ) (dB) |
Input Bias Current (Max) (pA) |
Offset Drift (Typ) (uV/C) |
GBW (Typ) (MHz) |
Output Current (Typ) (mA) |
2nd Harmonic (dBc) |
3rd Harmonic (dBc) |
@ MHz |
LMH6714 | LMH6720 | LMH6723 | LMH6724 |
Bipolar Current FB | Bipolar Current FB | Bipolar Current FB | Bipolar Current FB |
1 | 1 | 1 | 2 |
8 | 8 | 5 | 5 |
12 | 12 | 12 | 12 |
400 | 400 | 370 | 370 |
1 | 1 | 1 | 1 |
1800 | 1800 | 600 | 600 |
3.4 | 3.4 | 4.3 | 4.3 |
5.6 | 5.6 | 1 | 1 |
6 | 6 | 3 | 3 |
No | No | No | No |
N/A | Shutdown | N/A | N/A |
Catalog | Catalog | Catalog | Catalog |
-40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
SOIC SOT-23 | SOIC SOT-23 | SOIC SOT-23 | SOIC |
8SOIC: 29 mm2: 6 x 4.9(SOIC) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) |
54 | 54 | 60 | 60 |
10000000 | 10000000 | 4000000 | 4000000 |
8 | 8 | 0 | 0 |
70 | 70 | 110 | 110 |
58 | 58 | 65 | 65 |
70 | 70 | 63 | 63 |
20 | 20 | 5 | 5 |
