数据: OPA695 Ultra-Wideband, Current-Feedback Operational Amplifier With Disable 数据表
OPA695是一款高带宽,电流反馈运算放大器,具有出色的4300-V /μs压摆率和低输入电压噪声,可提供精密,低成本,高动态范围的中频(IF)放大器。 OPA695针对高增益操作进行了优化,非常适合缓冲IF条带中的表面声波(SAW)滤波器,或者为电缆调制解调器上游线路驱动器提供低失真的高输出功率。在较低的增益下,可实现1400 MHz的更高带宽,使OPA695成为支持高分辨率RGB应用的出色视频线驱动器。
OPA695低12.9 mA电源电流精确调整为+25 C。这种微调以及低温漂移可在整个温度范围内提供较低的系统功率。使用可选的禁用控制引脚可以进一步降低系统功耗。将此引脚保持打开状态或保持高电平可以正常工作。如果拉低,OPA695电源电流将降至170μA以下。这种节能特性,以及出色的单+ 5V工作和超小型SOT23-6封装,使OPA695成为便携式应用的理想选择。
Architecture |
Number of Channels (#) |
Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
BW @ Acl (MHz) |
Acl, min spec gain (V/V) |
Slew Rate (Typ) (V/us) |
Vn at Flatband (Typ) (nV/rtHz) |
Vn at 1kHz (Typ) (nV/rtHz) |
Iq per channel (Typ) (mA) |
Vos (Offset Voltage @ 25C) (Max) (mV) |
Rail-to-Rail |
Features |
Rating |
Operating Temperature Range (C) |
Package Group |
Package Size: mm2:W x L (PKG) |
CMRR (Typ) (dB) |
Input Bias Current (Max) (pA) |
Offset Drift (Typ) (uV/C) |
GBW (Typ) (MHz) |
Output Current (Typ) (mA) |
2nd Harmonic (dBc) |
3rd Harmonic (dBc) |
@ MHz |
OPA695 | LMH6702 | OPA2691 | OPA2695 | OPA3691 | OPA3695 | OPA691 | OPA694 |
Bipolar Current FB | Bipolar Current FB | Bipolar Current FB | Bipolar Current FB | Bipolar Current FB | Bipolar Current FB | Bipolar Current FB | Bipolar Current FB |
1 | 1 | 2 | 2 | 3 | 3 | 1 | 1 |
5 | 8 | 4 | 3.5 | 4 | 3.5 | 4 | 7 |
12 | 12 | 12 | 12 | 12 | 12 | 12 | 12.6 |
1700 | 1700 | 280 | 1100 | 280 | 1000 | 280 | 1500 |
1 | 1 | 1 | 1 | 1 | 2 | 1 | 1 |
4300 | 3100 | 2100 | 2900 | 2100 | 2400 | 2100 | 1700 |
1.8 | 1.83 | 1.7 | 1.8 | 1.7 | 1.8 | 1.7 | 2.1 |
12.9 | 12.5 | 5.1 | 12.9 | 5.1 | 12.9 | 5.1 | 5.8 |
3 | 4.5 | 3 | 3.5 | 3 | 3.5 | 2.5 | 3 |
No | No | No | No | No | No | No | No |
Shutdown | N/A | Shutdown | Small Size Shutdown | Shutdown | Shutdown | Shutdown | N/A |
Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
-40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
SOIC SOT-23 VSSOP | SOIC SOT-23 | SOIC SOIC | SOIC VQFN | SOIC SSOP | SSOP | SOIC SOT-23 | SOIC SOT-23 |
8SOIC: 29 mm2: 6 x 4.9(SOIC) 6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 14SOIC: 52 mm2: 6 x 8.65(SOIC) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 16VQFN: 9 mm2: 3 x 3(VQFN) | 16SOIC: 59 mm2: 6 x 9.9(SOIC) 16SSOP: 29 mm2: 6 x 4.9(SSOP) | 16SSOP: 29 mm2: 6 x 4.9(SSOP) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) |
56 | 48 | 56 | 56 | 56 | 56 | 56 | 60 |
30000000 | 15000000 | 35000000 | 30000000 | 35000000 | 30000000 | 35000000 | 20000000 |
15 | 13 | 20 | 15 | 20 | 15 | 20 | 15 |
120 | 80 | 190 | 120 | 190 | 120 | 190 | 80 |
65 | 100 | 70 | 73 | 70 | 65 | 70 | 68 |
86 | 96 | 74 | 82 | 74 | 86 | 74 | 72 |
10 | 5 | 5 | 10 | 5 | 10 | 5 | 5 |
