THS4304是一款宽带电压反馈运算放大器,设计用于采用单5V电源供电的高速模拟信号处理链。 THS4304采用BiCom3硅锗工艺技术开发,采用5 V单电源,与前几代需要±5 V电源的运算放大器相比,具有同类最佳性能。
THS4304是传统的电压反馈拓扑结构具有以下优势:平衡输入,低失调电压和失调电流,低失调漂移,高共模和电源抑制比。
THS4304采用8引脚MSOP封装(DGK),8引脚SOIC封装(D)和节省空间的5引脚SOT-23封装(DBV)。
Architecture |
Number of Channels (#) |
Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
BW @ Acl (MHz) |
Acl, min spec gain (V/V) |
Slew Rate (Typ) (V/us) |
Vn at Flatband (Typ) (nV/rtHz) |
Vn at 1kHz (Typ) (nV/rtHz) |
Iq per channel (Typ) (mA) |
Vos (Offset Voltage @ 25C) (Max) (mV) |
Rail-to-Rail |
Features |
Rating |
Operating Temperature Range (C) |
Package Group |
Package Size: mm2:W x L (PKG) |
CMRR (Typ) (dB) |
Input Bias Current (Max) (pA) |
Offset Drift (Typ) (uV/C) |
GBW (Typ) (MHz) |
Output Current (Typ) (mA) |
2nd Harmonic (dBc) |
3rd Harmonic (dBc) |
@ MHz |
THS4304 |
Bipolar Voltage FB |
1 |
2.7 |
5 |
3000 |
1 |
790 |
2.4 |
6.4 |
18 |
4 |
In Out |
N/A |
Catalog |
-40 to 85 |
SOIC SOT-23 VSSOP |
8SOIC: 29 mm2: 6 x 4.9(SOIC) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) |
95 |
12000000 |
5 |
3000 |
100 |
84 |
100 |
10 |
