OPAx365零交叉系列轨道至高性能CMOS运算放大器针对超低电压单电源应用进行了优化。轨至轨输入或输出,低噪声(4.5nV /√ Hz )和高速运行(50MHz增益带宽)使得这些器件非常适合驱动采样模数转换器(ADC)。应用包括音频,信号调节和传感器放大.OPA365系列运算放大器也非常适合手机功率放大器控制环路。
特殊特性,包括出色的共模抑制比(CMRR),无输入级交叉失真,高输入阻抗和轨至轨输入和输出摆幅。输入共模范围同时包括正负电源。输出电压摆幅在电源轨的10mV以内。
OPA365(单通道版本)采用微型SOT23-5( SOT-5)和SOIC-8封装.OPA2365(双通道版本)采用SOIC-8封装。所有版本的额定工作温度范围均为-40°C至+ 125°C。单通道和双通道版本具有完全相同的规范,可最大程度地提高设计灵活性。
所有商标均为其各自所有者的财产。
Architecture |
Number of Channels (#) |
Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
BW @ Acl (MHz) |
Acl, min spec gain (V/V) |
Slew Rate (Typ) (V/us) |
Vn at Flatband (Typ) (nV/rtHz) |
Vn at 1kHz (Typ) (nV/rtHz) |
Iq per channel (Typ) (mA) |
Vos (Offset Voltage @ 25C) (Max) (mV) |
Rail-to-Rail |
Features |
Rating |
Operating Temperature Range (C) |
Package Group |
Package Size: mm2:W x L (PKG) |
CMRR (Typ) (dB) |
Input Bias Current (Max) (pA) |
Offset Drift (Typ) (uV/C) |
GBW (Typ) (MHz) |
Output Current (Typ) (mA) |
2nd Harmonic (dBc) |
3rd Harmonic (dBc) |
@ MHz |
OPA2365 | OPA2365-Q1 | OPA365 | OPA365-EP | OPA365-Q1 |
CMOS Voltage FB | CMOS Voltage FB | CMOS Voltage FB | Voltage FB CMOS | CMOS Voltage FB |
2 | 2 | 1 | 1 | 1 |
2.2 | 2.2 | 2.2 | 2.2 | 2.2 |
5.5 | 5.5 | 5.5 | 5.5 | 5.5 |
50 | 50 | 50 | 50 | 50 |
1 | 1 | 1 | 1 | |
25 | 25 | 25 | 25 | 25 |
4.5 | 4.5 | 4.5 | 4.5 | 4.5 |
4.6 | 4.6 | 4.6 | 4.6 | 4.6 |
0.2 | 0.2 | 0.2 | 0.2 | 0.2 |
In Out | In Out | In Out | In Out | In Out |
Zero Crossover | Zero Crossover | Zero Crossover | Zero Crossover | Zero Crossover |
Catalog | Automotive | Catalog | HiRel Enhanced Product | Automotive |
-40 to 125 | -40 to 125 | -40 to 125 | -55 to 125 | -40 to 125 |
SOIC | SOIC | SOIC SOT-23 | SOT-23 | SOT-23 |
8SOIC: 29 mm2: 6 x 4.9(SOIC) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) |
120 | 120 | 120 | 120 | 120 |
10 | 10 | 10 | 10 | 10 |
1 | 1 | 1 | 3 | 1 |
65 | 65 | 65 | 65 | 65 |
81 | 81 | |||
93 | 93 | |||
1 | 1 | |||
