数据: Dual, Ultra-Wideband, Current-Feedback Operational Amplifier with Disable 数据表
OPA2695是一款双通道,高带宽,电流反馈运算放大器,具有出色的2900V /μs压摆率和低输入电压噪声,可提供精确度,低成本,高动态范围的中频(IF)放大器。该器件针对高增益工作进行了优化,两个可用封装(QFN-16,SO-8)的引脚输出经过优化,可提供对称的输入和输出路径。这种架构使OPA2695成为差分驱动器的理想选择,例如高速模数转换器(ADC)。
OPA2695低12.9mA /通道电源电流精确调整+ 25℃。这种微调以及低温漂移可在整个温度范围内提供较低的系统功率。使用可选的禁用控制引脚可以进一步降低系统功耗。将此引脚保持打开或保持高电平可以正常工作。如果拉低,OPA2695的电源电流将降至低于200μA/通道。这种省电功能以及出色的单+ 5V操作使OPA2695成为便携式应用的理想选择。 OPA2695采用SO-8(无禁用)封装或QFN-16封装(带禁用)。
PowerPAD是德州仪器公司的商标。
所有其他商标均为其各自所有者的财产。
Architecture |
Number of Channels (#) |
Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
BW @ Acl (MHz) |
Acl, min spec gain (V/V) |
Slew Rate (Typ) (V/us) |
Vn at Flatband (Typ) (nV/rtHz) |
Vn at 1kHz (Typ) (nV/rtHz) |
Iq per channel (Typ) (mA) |
Vos (Offset Voltage @ 25C) (Max) (mV) |
Rail-to-Rail |
Features |
Rating |
Operating Temperature Range (C) |
Package Group |
Package Size: mm2:W x L (PKG) |
CMRR (Typ) (dB) |
Input Bias Current (Max) (pA) |
Offset Drift (Typ) (uV/C) |
GBW (Typ) (MHz) |
Output Current (Typ) (mA) |
2nd Harmonic (dBc) |
3rd Harmonic (dBc) |
@ MHz |
OPA2695 | LMH6702 | OPA2691 | OPA3691 | OPA3695 | OPA691 | OPA694 | OPA695 |
Bipolar Current FB | Bipolar Current FB | Bipolar Current FB | Bipolar Current FB | Bipolar Current FB | Bipolar Current FB | Bipolar Current FB | Bipolar Current FB |
2 | 1 | 2 | 3 | 3 | 1 | 1 | 1 |
3.5 | 8 | 4 | 4 | 3.5 | 4 | 7 | 5 |
12 | 12 | 12 | 12 | 12 | 12 | 12.6 | 12 |
1100 | 1700 | 280 | 280 | 1000 | 280 | 1500 | 1700 |
1 | 1 | 1 | 1 | 2 | 1 | 1 | 1 |
2900 | 3100 | 2100 | 2100 | 2400 | 2100 | 1700 | 4300 |
1.8 | 1.83 | 1.7 | 1.7 | 1.8 | 1.7 | 2.1 | 1.8 |
12.9 | 12.5 | 5.1 | 5.1 | 12.9 | 5.1 | 5.8 | 12.9 |
3.5 | 4.5 | 3 | 3 | 3.5 | 2.5 | 3 | 3 |
No | No | No | No | No | No | No | No |
Small Size Shutdown | N/A | Shutdown | Shutdown | Shutdown | Shutdown | N/A | Shutdown |
Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
-40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
SOIC VQFN | SOIC SOT-23 | SOIC SOIC | SOIC SSOP | SSOP | SOIC SOT-23 | SOIC SOT-23 | SOIC SOT-23 VSSOP |
8SOIC: 29 mm2: 6 x 4.9(SOIC) 16VQFN: 9 mm2: 3 x 3(VQFN) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 14SOIC: 52 mm2: 6 x 8.65(SOIC) | 16SOIC: 59 mm2: 6 x 9.9(SOIC) 16SSOP: 29 mm2: 6 x 4.9(SSOP) | 16SSOP: 29 mm2: 6 x 4.9(SSOP) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) |
56 | 48 | 56 | 56 | 56 | 56 | 60 | 56 |
30000000 | 15000000 | 35000000 | 35000000 | 30000000 | 35000000 | 20000000 | 30000000 |
15 | 13 | 20 | 20 | 15 | 20 | 15 | 15 |
120 | 80 | 190 | 190 | 120 | 190 | 80 | 120 |
73 | 100 | 70 | 70 | 65 | 70 | 68 | 65 |
82 | 96 | 74 | 74 | 86 | 74 | 72 | 86 |
10 | 5 | 5 | 5 | 10 | 5 | 5 | 10 |
型号:OPA2695ID 封装:SOIC8_150MIL
品牌:TI 描述:高速运算放大器 (>=50Mhz) 差分 2通道 PSRR=56dB 2.9KV/μs SOIC8_150MIL
金额:¥
去购买
