数据: Broadband, Fully Differential 14-/16-Bit ADC Driver Amplifier.. 数据表
THS770012是一款宽带全差分放大器,可调增益范围为+ 10dB至+ 13.7dB(带外部元件)。它专为驱动高达130MHz输入频率的16位模数转换器(ADC)和输入频率高达200MHz的14位ADC而设计和优化。该器件提供高带宽,高压输出,低失真和低噪声,对于需要非常高动态范围的高速数据采集系统至关重要,例如无线基站和测试和测量应用。该器件还是一款出色的差分放大器,适用于通用,高速差分信号链和短线驱动器应用。
THS770012采用标称+ 5V单电源供电,速度极快,最大7.5ns从过载条件恢复时间,并具有省电模式。 THS770012采用无铅(符合RoHS标准)和绿色QFN-24热增强型封装。它的特点是在-40°C至+ 85°C的工业温度范围内工作。
Architecture |
Number of Channels (#) |
Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
BW @ Acl (MHz) |
Acl, min spec gain (V/V) |
Slew Rate (Typ) (V/us) |
Vn at Flatband (Typ) (nV/rtHz) |
Iq per channel (Typ) (mA) |
Vos (Offset Voltage @ 25C) (Max) (mV) |
Rail-to-Rail |
Features |
Rating |
Operating Temperature Range (C) |
Package Group |
Package Size: mm2:W x L (PKG) |
CMRR (Typ) (dB) |
Input Bias Current (Max) (pA) |
GBW (Typ) (MHz) |
Output Current (Typ) (mA) |
2nd Harmonic (dBc) |
3rd Harmonic (dBc) |
@ MHz |
THS770012 | THS770006 |
Current FB Fully Differential | Current FB Fully Differential |
1 | 1 |
4.75 | 4.75 |
5.25 | 5.25 |
900 | 2400 |
4 | 2 |
3400 | 3200 |
1.5 | 1.7 |
100 | 100 |
5 | 5 |
No | No |
Shutdown | Shutdown |
Catalog | Catalog |
-40 to 85 | -40 to 85 |
VQFN | VQFN |
24VQFN: 16 mm2: 4 x 4(VQFN) | 24VQFN: 16 mm2: 4 x 4(VQFN) |
60 | 60 |
400000000 | 400000000 |
900 | 2400 |
80 | 80 |
90 | 87 |
100 | 103 |
10 | 10 |
