THS3491电流反馈放大器(CFA)可以为需要在从直流到大于100MHz值(负载为100Ω)的高输出功率水平实现最低失真的应用提供更出色的性能。尽管该电流反馈设计的额定增益为5V /V,但它能够在宽增益范围内保持几乎恒定的带宽和失真。
8000V /μs的压摆率能够以低失真和100MHz的频率为严苛的负载提供10V PP 的输出.900MHz,小信号带宽能够以10V阶跃以及小于1.3ns的上升和下降时间提供小于1.5%的低过冲。大于500mA的峰值输出电流驱动值能够以快速的信号驱动高电容负载。
通过使用VQFN-16(RGT)封装,新设计能够从最低的失真获益,而8引脚HSOIC(DDA)封装(具有PowerPAD™)可升级现有的THS3091或THS3095设计。与传统的THS3091或THS3095选项相比,THS3491的更低输出余量能够在相同的±15V电源下提供更大的输出摆幅。
所有商标均为其各自所有者的财产。
Architecture |
Number of Channels (#) |
Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
BW @ Acl (MHz) |
Acl, min spec gain (V/V) |
Slew Rate (Typ) (V/us) |
Vn at Flatband (Typ) (nV/rtHz) |
Vn at 1kHz (Typ) (nV/rtHz) |
Iq per channel (Typ) (mA) |
Vos (Offset Voltage @ 25C) (Max) (mV) |
Rail-to-Rail |
Features |
Rating |
Operating Temperature Range (C) |
Package Group |
Package Size: mm2:W x L (PKG) |
CMRR (Typ) (dB) |
Input Bias Current (Max) (pA) |
Offset Drift (Typ) (uV/C) |
GBW (Typ) (MHz) |
Output Current (Typ) (mA) |
2nd Harmonic (dBc) |
3rd Harmonic (dBc) |
@ MHz |
THS3491 | THS3091 | THS3095 |
Current FB | Bipolar Current FB | Bipolar Current FB |
1 | 1 | 1 |
14 | 10 | 10 |
32 | 30 | 30 |
900 | 235 | 235 |
1 | 1 | 1 |
8000 | 7300 | 7300 |
1.85 | 2 | 2 |
3 | 2 | 2 |
17.1 | 9.5 | 9.5 |
2 | 3 | 3 |
No | No | No |
Shutdown | N/A | Shutdown |
Catalog | Catalog | Catalog |
-40 to 85 | -40 to 85 | -40 to 85 |
SO PowerPAD VQFN | SO PowerPAD SOIC | SO PowerPAD SOIC |
8SO PowerPAD: 19 mm2: 3.9 x 4.89(SO PowerPAD) 16VQFN: 9 mm2: 3 x 3(VQFN) | 8SO PowerPAD: 19 mm2: 3.9 x 4.89(SO PowerPAD) 8SOIC: 29 mm2: 6 x 4.9(SOIC) | 8SO PowerPAD: 19 mm2: 3.9 x 4.89(SO PowerPAD) 8SOIC: 29 mm2: 6 x 4.9(SOIC) |
75 | 69 | 69 |
5000000 | 15000000 | 15000000 |
3 | 10 | 10 |
900 | 235 | 235 |
420 | 250 | 250 |
76 | 66 | 66 |
69 | 74 | 74 |
50 | 10 | 10 |
