数据: TLV3011, TLV3012: Nanopower, 1.8V, SOT23 Comparator with Voltage Reference 数据表
TLV3011是一款低功耗,漏极开路输出比较器; TLV3012是一款推挽输出比较器。两者都具有未提交的片上电压基准。两者均具有5μA(最大值)静态电流,输入共模范围超出电源轨200mV,单电源工作电压范围为1.8V至5.5V。集成的1.242V系列电压基准提供低100ppm /°C(最大值)漂移,在高达10nF容性负载下稳定,并可提供高达0.5mA(典型值)的输出电流。
TLV3011 TLV3012采用纤巧SOT23-6封装,适用于大多数空间保守设计。它还采用SC70封装,可节省更多的电路板面积。两种版本的温度范围均为40°C至+ 125°C。
Number of Channels (#) |
Output Type |
Vs (Min) (V) |
Vs (Max) (V) |
Propagation Delay Time (uS) |
Vos (Offset Voltage @ 25C) (Max) (mV) |
Iq per channel (Typ) (mA) |
Input Bias Current (+/-) (Max) (nA) |
Rail-to-Rail |
Rating |
Operating Temperature Range (C) |
Features |
Reference Voltage (V) |
VICR (Max) (V) |
VICR (Min) (V) |
Package Group |
TLV3012 | TLV3011 | TLV3012-Q1 |
1 | 1 | 1 |
Push-Pull | Open Collector | Push-Pull |
1.8 | 1.8 | 1.8 |
5.5 | 5.5 | 5.5 |
6 | 6 | 6 |
12 | 12 | 12 |
0.0028 | 0.0028 | 0.0028 |
0.01 | 0.01 | 0.01 |
In | In | In |
Catalog | Catalog | Automotive |
-40 to 85 | -40 to 125 | -40 to 125 |
Internal Reference Small Size | Internal Reference Small Size | Internal Reference Small Size |
1.242 | 1.242 | 1.242 |
5.7 | 5.7 | 5.7 |
-0.2 | -0.2 | -0.2 |
SC70 SOT-23 | SC70 SOT-23 | SC70 |
