TLV7081是一款单通道纳米功率比较器,工作电压低至1.7 V.该比较器采用超小型WCSP封装,电压为0.7毫米×0.7毫米,使TLV7081适用于智能手机和其他便携式电池供电应用等空间关键设计。
TLV7081具有宽输入电压范围,与电源电压无关。具有输入范围即使TLV7081未上电,TLV7081也可以直接连接到有效的电源。
TLV7081有一个开漏输出级,可以拉到V +以上,这样就可以了用于电平转换器和双极到单端转换器。
所有商标均为他们各自的所有者。
Number of Channels (#) |
Output Type |
Vs (Min) (V) |
Vs (Max) (V) |
Propagation Delay Time (uS) |
Vos (Offset Voltage @ 25C) (Max) (mV) |
Iq per channel (Typ) (mA) |
Input Bias Current (+/-) (Max) (nA) |
Rail-to-Rail |
Rating |
Operating Temperature Range (C) |
Features |
VICR (Max) (V) |
VICR (Min) (V) |
Package Group |
TLV7081 | TLV7021 | TLV7031 | TLV7041 |
1 | 1 | 1 | 1 |
Open Drain | Open Drain | Push-Pull | Open Drain |
1.7 | 1.6 | 1.6 | 1.6 |
5.5 | 5.5 | 6.5 | 6.5 |
4 | 0.26 | 3 | 3 |
10 | 8 | 8 | 8 |
0.000379 | 0.005 | 0.000335 | 0.000335 |
0.01 | 0.005 | 0.002 | 0.002 |
In Out | In | In Out | In Out |
Catalog | Catalog | Catalog | Catalog |
-40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
Hysteresis Small Size | Hysteresis Small Size | Hysteresis Small Size | Hysteresis Small Size |
6.6 | 5.6 | 6.6 | 6.6 |
0 | 0 | 0 | 0 |
DSBGA | SC70 X2SON | SC70 X2SON | SC70 X2SON |
