数据: INA1x9-Q1 Automotive-Grade, High-Side, Current-Output, Current-Shunt Monitor 数据表
INA139-Q1和INA169-Q1(INA1x9-Q1)是高端,单向,电流分流监控器。宽输入共模电压范围,高速,低静态电流和TSSOP-8封装可用于各种应用。
该器件将差分输入电压转换为电流输出。该电流通过外部负载电阻转换回电压,可将任何增益设置为1到100以上。虽然设计用于电流分流测量,但该电路可以在测量和电平转换方面引人注目。
INA139-Q1和INA169-Q1采用TSSOP-8封装,工作在-40°C至+ 125°C温度范围。
Common Mode Voltage (Max) (V) |
Common Mode Voltage (Min) (V) |
Input Offset (+/-) (Max) (uV) |
Input Offset Drift (+/-) (Typ) (uV/C) |
Gain (V/V) |
Gain Error (%) |
Gain Error Drift (Max) (ppm/°C) |
CMRR (Min) (dB) |
Bandwidth (kHz) |
Supply Voltage (Max) (V) |
Supply Voltage (Min) (V) |
Iq (Max) (mA) |
Number of Channels (#) |
Features |
Rating |
Operating Temperature Range (C) |
Package Group |
Package Size: mm2:W x L (PKG) |
INA139-Q1 | INA138-Q1 | INA168-Q1 | INA169-Q1 |
36 | 36 | 60 | 60 |
2.7 | 2.7 | 2.7 | 2.7 |
2000 | 2000 | 2000 | 2000 |
1 | 1 | 1 | 1 |
Adjustable | Adjustable | Adjustable | Adjustable |
2 | 3.2 | 3.2 | 2 |
100 | 150 | 150 | 100 |
100 | 100 | 100 | 100 |
4400 | 800 | 800 | 4400 |
40 | 36 | 60 | 60 |
0.125 | 0.06 | 0.06 | 0.125 |
1 | 1 | 1 | 1 |
Current Output | Current Output | Current Output | Current Output |
Automotive | Automotive | Automotive | Automotive |
-40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
TSSOP | TSSOP | SOT-23 TSSOP | TSSOP |
8TSSOP: 19 mm2: 6.4 x 3(TSSOP) | 8TSSOP: 19 mm2: 6.4 x 3(TSSOP) | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) 8TSSOP: 19 mm2: 6.4 x 3(TSSOP) | 8TSSOP: 19 mm2: 6.4 x 3(TSSOP) |
