INA199系列电压输出,也称为电流传感放大器闭环反馈电路。该系列器件可在独立于电源电压的-0.3V至26V共模电压下感应分流电阻器上的电压降。共有三种固定增益可供选择:50V /V,100V /V和200V /V.该系列器件采用零漂移架构,偏移较低,因此在进行电流感测能能将分流电阻器两端的最大压降保持在最低10mV的满量程。
这些器件由2.7V至26V的单个电源供电,消耗的最大电源电流为100μA。并且提供了SC70-6和薄型UQFN-10两种封装。 /p>
所有商标均为其各自所有者的财产。
Common Mode Voltage (Max) (V) |
Common Mode Voltage (Min) (V) |
Input Offset (+/-) (Max) (uV) |
Input Offset Drift (+/-) (Typ) (uV/C) |
Gain (V/V) |
Gain Error (%) |
Gain Error Drift (Max) (ppm/°C) |
CMRR (Min) (dB) |
Bandwidth (kHz) |
Supply Voltage (Max) (V) |
Supply Voltage (Min) (V) |
Iq (Max) (mA) |
Number of Channels (#) |
Features |
Rating |
Operating Temperature Range (C) |
Package Group |
Package Size: mm2:W x L (PKG) |
INA199 | INA180 | INA181 | INA190 | INA210 |
26 | 26 | 26 | 40 | 26 |
-0.1 | -0.2 | -0.2 | -0.1 | -0.3 |
150 | 150 | 150 | 15 20 25 | 35 60 100 |
0.1 | 0.2 | 0.2 | 0.05 | 0.1 |
50 | 100 20 200 50 | 100 20 200 50 | 100 200 25 50 | 100 1000 200 50 500 75 |
1 | 1 | 1 | 0.3 | 0.5 |
10 | 20 | 20 | 5 | 10 |
100 | 84 | 84 | 120 | 105 |
80 30 14 | 350 210 150 105 | 350 210 150 105 | 40 37 35 30 20 | 80 40 30 14 7 4 |
26 | 5.5 | 5.5 | 5.5 | 26 |
2.7 | 2.7 | 2.7 | 1.7 | 2.7 |
0.115 | 0.3 | 0.3 | 70 | 0.115 |
1 | 1 | 1 | 1 | 1 |
Bi-directional Low-side Capable | Low-side Capable | Bi-directional Low-side Capable | Bi-directional Low-side Capable | Bi-directional Low-side Capable |
Catalog | Catalog | Catalog | Catalog | Catalog |
-40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
SC70 UQFN | SOT-23 | SOT-23 | UQFN | SC70 UQFN |
6SC70: 4 mm2: 2.1 x 2(SC70) 10UQFN: 3 mm2: 1.4 x 1.8(UQFN) | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 10UQFN: 3 mm2: 1.4 x 1.8(UQFN) | 6SC70: 4 mm2: 2.1 x 2(SC70) 10UQFN: 3 mm2: 1.4 x 1.8(UQFN) |
