INA302和INA303器件具有一个高共模,双向电流传感放大器和两个高速比较器,用于检测超出范围的电流状况.INA302比较器配置为检测和响应过流状况.INA303比较器配置为在窗口配置中响应过流和欠流状况。该器件每个一个可调节限制阈值范围,该范围通过一个外部限值设定电阻进行设置。这些电流分流监控器可在独立于电源的-0.1V至36V共模电压范围内测量差动电压信号。
开漏极警报输出可配置为在透明模式(输出状态)与输入状态保持一致)或运存模式(警报输出在锁存复位时清除)下运行。比较器1的警报响应时间小于1μs,而比较器2的警报响应时间通过外部电容器进行设置,范围介于2μs至10s之间。
此装件由2.7V至5.5V的单个电源供电,消耗的最大电源电流为950μA。该器件具有扩展级工作温度范围( 40℃至+ 125℃),并且采用14引脚TSSOP封装。
Common Mode Voltage (Max) (V) |
Common Mode Voltage (Min) (V) |
Input Offset (+/-) (Max) (uV) |
Input Offset Drift (+/-) (Typ) (uV/C) |
Gain (V/V) |
Gain Error (%) |
Gain Error Drift (Max) (ppm/°C) |
CMRR (Min) (dB) |
Bandwidth (kHz) |
Supply Voltage (Max) (V) |
Supply Voltage (Min) (V) |
Iq (Max) (mA) |
Number of Channels (#) |
Comparators (#) |
Features |
Rating |
Operating Temperature Range (C) |
Package Group |
Package Size: mm2:W x L (PKG) |
INA303 | INA300 | INA301 | INA302 | INA381 |
36 | 36 | 36 | 36 | 26 |
0 | 0 | 0 | 0 | -0.2 |
30 50 80 | 650 | 35 50 125 | 30 50 80 | 150 |
0.1 | 0.1 | 0.1 | 0.1 | 0.2 |
100 20 50 | 100 20 50 | 100 20 50 | 100 20 200 50 | |
0.1 0.15 0.2 | 0.1 0.15 0.2 | 0.1 0.15 0.2 | 1 | |
10 | 10 | 10 | 20 | |
100 | 96 | 100 | 100 | 84 |
550 500 450 | 550 500 450 | 550 440 400 | 350 | |
5.5 | 5.5 | 5.5 | 5.5 | 5.5 |
2.7 | 2.7 | 2.7 | 2.7 | 2.7 |
1.1 | 0.135 | 0.7 | 1.1 | 0.5 |
1 | 1 | 1 | 1 | 1 |
2 | 1 | 1 | 2 | 1 |
Alert Function Bi-directional Low-side Capable | Alert Function Low-side Capable | Alert Function Low-side Capable | Alert Function Bi-directional Low-side Capable | Alert Function Low-side Capable |
Catalog | Catalog | Catalog | Catalog | Catalog |
-40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
TSSOP | VSSOP WSON | VSSOP | TSSOP | WSON |
14TSSOP: 32 mm2: 6.4 x 5(TSSOP) | 10VSSOP: 15 mm2: 4.9 x 3(VSSOP) See datasheet (WSON) | 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) | See datasheet (WSON) |
