LM386M-1和LM386MX-1是专为低电压消耗应用而设计的功率放大器。增益在内部设置为20,以保持外部元件数低,但在引脚1和8之间增加一个外部电阻和电容将增益增加到20到200之间的任何值。
输入接地参考而输出自动偏置到供电电压的一半。采用6 V电源供电时,静态功耗仅为24 mW,这使得LM386M-1和LM386MX-1非常适合电池供电。
所有商标均为其各自所有者的财产。
Audio Input Type |
Architecture |
Speaker Channels (Max) |
Power Stage Supply (Min) (V) |
Power Stage Supply (Max) (V) |
Output Power (W) |
Load (Min) (ohms) |
THD + N @ 1 kHz (%) |
Iq (Typ) (mA) |
Control Interface |
Closed/Open Loop |
Analog Supply (V) (Min) |
Analog Supply (V) (Max) |
PSRR (dB) |
Operating Temperature Range (C) |
Rating |
LM386 |
Analog Input |
Class-AB |
Mono |
20 |
94 |
0.325 |
4 |
0.2 |
4 |
Hardware |
Closed |
20 |
94 |
50 |
0 to 70 |
Catalog |
