数据: 20-W STEREO DIGITAL AUDIO POWER AMPLIFIER WITH EQ AND DRC, 数据表
TAS5707是一款20W,高效的数字音频功率放大器,用于驱动立体声桥接扬声器。一个串行数据输入允许处理多达两个离散音频通道,并与大多数数字音频处理器和MPEG解码器无缝集成。该器件可接受各种输入数据和数据速率。完全可编程的数据路径将这些通道路由到内部扬声器驱动器。
TAS5707是一个仅从设备,接收来自外部源的所有时钟。 TAS5707采用PWM载波工作,开关速率为384 kHz,开关速率为352-KHz,具体取决于输入采样速率。过采样与四阶噪声整形器相结合,可提供平坦的本底噪声和20 Hz至20 kHz的优异动态范围。
TAS5707A的功能与HTQFP封装的TAS5707相同,但具有独特的I < sup> 2 C设备地址。 TAS5707的地址是0x36。 TAS5707A的地址为0x3A。
所有商标均为其各自所有者的财产。
Audio Input Type |
Architecture |
Speaker Channels (Max) |
Power Stage Supply (Min) (V) |
Power Stage Supply (Max) (V) |
Output Power (W) |
Load (Min) (ohms) |
SNR (dB) |
THD + N @ 1 kHz (%) |
Iq (Typ) (mA) |
Control Interface |
Closed/Open Loop |
Analog Supply (V) (Min) |
Analog Supply (V) (Max) |
Power to Parallel Bridge Tied Load (Max) (W) |
Sampling Rate (Max) (kHz) |
Operating Temperature Range (C) |
Rating |
TAS5707 | TAS5733L | TAS5751M | TAS5753MD |
Digital Input | Digital Input | Digital Input | Digital Input |
Class-D | Class-D | Class-D | Class-D |
Stereo | Stereo | Stereo | Stereo |
8 | 8 | 8 | 8 |
26 | 16.5 | 26.4 | 26.4 |
20 | 12 | 25 | 20 |
6 | 4 | 4 | 2 |
106 | 104 | 106 | 105 |
0.05 | 0.25 | 0.03 | 0.13 |
29 | 23 | 23 | 23 |
Hardware Software | Software | Software | I2C |
Open | Closed | Open | Open |
3 | 3 | 3 | 3 |
3.6 | 3.6 | 3.6 | 3.6 |
50 | 65 | 65 | |
48 | 48 | 48 | 48 |
0 to 85 | 0 to 85 | 0 to 85 | 0 to 85 |
Catalog | Catalog | Catalog | Catalog |
