TPA6203A1是一款1.25 W单声道全差动放大器,设计用于驱动至少8Ω阻抗的扬声器,耗电量小于37 mm 2 (ZQV封装选项)大多数应用中的总印刷电路板(PCB)面积。该器件工作电压为2.5 V至5.5 V,静态电源电流仅为1.7 mA。 TPA6203A1采用节省空间的2 mm x 2 mm MicroStar Junior BGA封装,节省空间的3 mm x 3 mm QFN(DRB)封装。
90 Hz的85 dB PSRR等特性TPA6203A1至5 kHz,改善了RF整流抗扰度,并且PCB面积小,是无线手机的理想选择。 TPA6203A1具有4μs的快速启动时间和最小的弹出功能,是PDA应用的理想选择。
Audio Input Type |
Architecture |
Speaker Channels (Max) |
Power Stage Supply (Min) (V) |
Power Stage Supply (Max) (V) |
Output Power (W) |
Load (Min) (ohms) |
SNR (dB) |
THD + N @ 1 kHz (%) |
Iq (Typ) (mA) |
Control Interface |
Closed/Open Loop |
Analog Supply (V) (Min) |
Analog Supply (V) (Max) |
PSRR (dB) |
Operating Temperature Range (C) |
Rating |
TPA6203A1 | TPA6204A1 | TPA6205A1 | TPA6211A1 |
Analog Input | Analog Input | Analog Input | Analog Input |
Class-AB | Class-AB | Class-AB | Class-AB |
Mono | Mono | Mono | Mono |
2.5 | 2.5 | 2.5 | 2.5 |
5.5 | 5.5 | 5.5 | 5.5 |
1.25 | 1.7 | 1.25 | 3.1 |
8 | 8 | 8 | 3 |
104 | 105 | 104 | 105 |
0.06 | 0.02 | 0.06 | 0.03 |
1.7 | 4 | 1.7 | 4 |
Hardware | Hardware | Hardware | Hardware |
Closed | Closed | Closed | Closed |
90 | 85 | 90 | 85 |
-40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
Catalog | Catalog | Catalog | Catalog |
