数据: TAS5751M - Digital Input Audio Power Amplifier with EQ and 3-Band AGL 数据表
TAS5751M器件是一款高效的数字输入音频放大器,用于驱动配置为桥接负载(BTL)的立体声扬声器。并联桥接负载(PBTL)通过将并行输出驱动为单个较低阻抗负载可以产生更高功率。一个串行数据输入允许处理多达两个离散音频通道,并与大多数数字音频处理器和MPEG解码器无缝集成。该器件可接受各种输入数据和数据速率。完全可编程的数据路径将这些通道路由到内部驱动器驱动程序。
TAS5751M器件是一个仅从器件,可接收外部源的所有时钟。 TAS5751M器件采用PWM载波工作,开关速率为384 kHz,开关速率为288 kHz,具体取决于输入采样率。过采样与四阶噪声整形器相结合,提供平坦的本底噪声和20 Hz至20 Hz的优异动态范围。 20千赫。
全部商标a重新拥有各自所有者的财产。
Audio Input Type |
Architecture |
Speaker Channels (Max) |
Power Stage Supply (Min) (V) |
Power Stage Supply (Max) (V) |
Output Power (W) |
Load (Min) (ohms) |
SNR (dB) |
THD + N @ 1 kHz (%) |
Iq (Typ) (mA) |
Control Interface |
Closed/Open Loop |
Analog Supply (V) (Min) |
Analog Supply (V) (Max) |
Power to Parallel Bridge Tied Load (Max) (W) |
Sampling Rate (Max) (kHz) |
PSRR (dB) |
Operating Temperature Range (C) |
Rating |
TAS5751M | TAS5103 | TAS5601 | TAS5701 | TAS5705 | TAS5707 | TAS5707A | TAS5711 | TAS5713 | TAS5715 | TAS5719 | TAS5727 | TAS5733L | TAS5753MD | TAS5754M | TAS5756M | TAS5760M | TAS5782M | TAS5805M | TAS5825M |
Digital Input | PWM | PWM | Digital Input | Digital Input | Digital Input | Digital Input | Digital Input | Digital Input | Digital Input | Digital Input | Digital Input | Digital Input | Digital Input | Digital Input | Digital Input | Digital Input | Digital Input | Digital Input | Digital Input |
Class-D | Class-D | Class-D | Class-D | Class-D | Class-D | Class-D | Class-D | Class-D | Class-D | Class-D | Class-D | Class-D | Class-D | Class-D | Class-D | Class-D | Class-D | Class-D | Class-D |
Stereo | 4 | 4 | Stereo | Stereo | Stereo | Stereo | 3 | Stereo | Stereo | Stereo | Stereo | Stereo | Stereo | Stereo | Stereo | Stereo | Stereo | Stereo | Stereo |
8 | 8 | 10 | 10 | 8 | 8 | 8 | 8 | 8 | 8 | 4.5 | 8 | 8 | 8 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 |
26.4 | 23 | 26 | 21 | 23 | 26 | 26 | 26 | 26 | 26 | 26 | 26 | 16.5 | 26.4 | 26.4 | 26.4 | 26.4 | 26.4 | 26.4 | 26.4 |
25 | 20 | 20 | 20 | 20 | 20 | 20 | 20 | 25 | 25 | 15 | 25 | 12 | 20 | 40 | 40 | 55 | 40 | 23 | 40 |
4 | 4 | 4 | 6 | 6 | 6 | 6 | 4 | 4 | 4 | 4 | 4 | 4 | 2 | 2 | 2 | 2 | 3 | 4 | 3.2 |
106 | 100 | 99 | 100 | 105 | 106 | 106 | 106 | 106 | 106 | 105 | 106 | 104 | 105 | 103 | 104 | 100 | 103 | 107 | 107 |
0.03 | 0.1 | 0.004 | 0.05 | 0.24 | 0.05 | 0.06 | 0.06 | 0.03 | 0.03 | 0.13 | 0.03 | 0.25 | 0.13 | 0.007 | 0.006 | 0.03 | 0.2 | 0.03 | 0.04 |
23 | 0.01 | 35 | 30 | 30 | 29 | 29 | 29 | 31 | 31 | 26 | 26 | 23 | 23 | 16.5 | |||||
Software | Hardware | Hardware | Hardware | Hardware Software | Hardware Software | Hardware Software | Software | Software | Software | Software | Software | Software | I2C | Software | Software | Hardware Software | Software | I2C | Software |
Open | Open | Closed | Open | Open | Open | Open | Open | Open | Open | Open | Open | Closed | Open | Closed | Closed | Closed | Closed | Closed | Closed |
3 | 3 | 10 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 3 | 2.9 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 |
3.6 | 3.6 | 26 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.63 | 26.4 | 26.4 | 26.4 | 26.4 | 26.4 |
65 | 53 | 42.8 | 41.5 | 50 | 70 | 50 | 65 | 75 | 75 | 43.2 | 40 | 45 | 80 | ||||||
48 | 192 | 200 | 192 | 192 | 48 | 48 | 48 | 48 | 48 | 48 | 48 | 48 | 48 | 192 | 192 | 96 | 96 | 96 | 192 |
60 | |||||||||||||||||||
0 to 85 | 0 to 70 | -40 to 85 | 0 to 85 | 0 to 85 | 0 to 85 | 0 to 85 | 0 to 85 | 0 to 85 | 0 to 85 | 0 to 85 | 0 to 85 | 0 to 85 | 0 to 85 | -25 to 85 | -25 to 85 | -25 to 85 | -25 to 85 | -25 to 85 | -25 to 85 |
Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
型号:TAS5751MDCAR 封装:HTSSOP48_12.5X6.1MM_EP
品牌:TI 描述:带 EQ 和 AGL 功能的 25W 立体声、40W 单声道、8V 至 26.4V、数字输入、开环 D 类音频放大器
金额:¥7.91452
去购买
