TAS5825M是一款高性能立体声闭环D类集成音频处理器,具有高达192 kHz的架构。
强大的DSP音频处理内核支持多种先进的音频处理流程。采用192-kHz架构,TAS5825M提供出色的处理能力。例如2×12 BQ,音量控制,音频混音器,2频段DRC和全频段AGL。采用48 kHz或96 kHz架构,集成的SRC(采样率转换器)可检测输入采样率变化。然后自动转换DSP正在运行的目标采样率,以避免任何音频伪像。这些工艺流程支持:2×15 BQ,3频段DRC,全频段AGL(自动增益限制器),智能放大器算法(扬声器散热,偏移保护),低音增强,空间化器和THD管理器。
所有商标均为其各自所有者的财产。
| Audio Input Type |
| Architecture |
| Speaker Channels (Max) |
| Power Stage Supply (Min) (V) |
| Power Stage Supply (Max) (V) |
| Output Power (W) |
| Load (Min) (ohms) |
| SNR (dB) |
| THD + N @ 1 kHz (%) |
| Iq (Typ) (mA) |
| Control Interface |
| Closed/Open Loop |
| Analog Supply (V) (Min) |
| Analog Supply (V) (Max) |
| Power to Parallel Bridge Tied Load (Max) (W) |
| Sampling Rate (Max) (kHz) |
| Operating Temperature Range (C) |
| Rating |
| TAS5825M | TAS5751M | TAS5782M |
| Digital Input | Digital Input | Digital Input |
| Class-D | Class-D | Class-D |
| Stereo | Stereo | Stereo |
| 4.5 | 8 | 4.5 |
| 26.4 | 26.4 | 26.4 |
| 40 | 25 | 40 |
| 3.2 | 4 | 3 |
| 107 | 106 | 103 |
| 0.04 | 0.03 | 0.2 |
| 23 | ||
| Software | Software | Software |
| Closed | Open | Closed |
| 4.5 | 3 | 4.5 |
| 26.4 | 3.6 | 26.4 |
| 80 | 65 | 40 |
| 192 | 48 | 96 |
| -25 to 85 | 0 to 85 | -25 to 85 |
| Catalog | Catalog | Catalog |
