TPS4005x是一系列高压,宽输入(8 V至40 V)同步降压转换器。 TPS4005x系列具有设计灵活性和各种用户可编程功能,包括软启动,UVLO,工作频率,电压前馈,高端电流限制和环路补偿。
TPS4005x也可以同步外部供应。它们采用MOSFET栅极驱动器,用于外部N沟道高侧和同步整流器(SR)MOSFET。栅极驱动逻辑采用反交叉传导电路,可防止同时进行高端和同步整流传导。
TPS4005x采用电压前馈控制技术,在宽(4:1)输入端提供良好的线路调节电压范围,输入线瞬态快速响应,输入变化接近恒定增益,简化了环路补偿。
外部可编程电流限制提供逐脉冲电流限制,以及利用打嗝模式操作内部故障计数器,用于较长时间的过载。
PowerPAD是德州仪器的商标。
Vin (Min) (V) |
Vin (Max) (V) |
Vout (Min) (V) |
Vout (Max) (V) |
Iout (Max) (A) |
Regulated Outputs (#) |
Number of Phases |
Switching Frequency (Min) (kHz) |
Switching Frequency (Max) (kHz) |
Iq (Typ) (mA) |
Features |
Duty Cycle (Max) (%) |
Operating Temperature Range (C) |
Rating |
Package Group |
Control Mode |
TPS40050-Q1 | TPS40051-Q1 | TPS40090-Q1 | TPS40170-Q1 | TPS40200-Q1 |
8 | 8 | 4.5 | 4.5 | 4.5 |
40 | 40 | 15 | 60 | 52 |
0.7 | 0.7 | 0.7 | 0.6 | 0.7 |
35 | 35 | 3.3 | 57 | 46 |
20 | 20 | 120 | 20 | 3 |
1 | 1 | 1 | 1 | 1 |
1 | 1 | 4 | 1 | 1 |
100 | 100 | 100 | 100 | 35 |
1000 | 1000 | 1000 | 600 | 500 |
1.5 | 1.5 | 4 | 4.5 | 1.5 |
Enable Frequency Synchronization Synchronous Rectification | Enable Frequency Synchronization Synchronous Rectification | Adjustable Current Limit Enable Frequency Synchronization Phase Interleaving Power Good Synchronous Rectification | Adjustable Current Limit Enable Frequency Synchronization Power Good Pre-Bias Start-Up Synchronous Rectification Tracking UVLO Adjustable | Frequency Synchronization |
85 | 85 | 87.5 | 95 | 95 |
-40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
Automotive | Automotive | Automotive | Automotive | Automotive |
HTSSOP | HTSSOP | TSSOP | VQFN | SOIC |
Voltage Mode | Voltage Mode | Current Mode | Voltage Mode | Voltage Mode |
