LM3102同步整流降压转换器采用实现低成本高效率的降压稳压器所需的全部功能。该器件可为负载提供2.5 A电流以及低至0.8V的输出电压。双N沟道同步MOSFET开关可减少组件数量,从而降低电路复杂度并最大限度地减小电路板尺寸。
LM3102不同于大多数其他COT稳压器,因为它不依赖输出电容器ESR来获得稳定性,专为与陶瓷及其他ESR极低的输出电容器完美配合工作而设计。该器件无需环路补偿,可提供快速负载瞬态响应并实现简单电路。由于输入电压和导通时间之间呈反比关系,因此在线路发生变化时,器件的工作频率几乎保持恒定。通过外部编程,工作频率可高达1MHz。
保护特性包括V CC 欠压锁定(UVLO),输出过压保护,热关断和栅极驱动欠压锁定.LM3102采用热增强型HTSSOP-20封装,而且LM3102还可以采用输电流降低的DSBGA低厚度芯片级封装。
Vin (Min) (V) |
Vin (Max) (V) |
Vout (Min) (V) |
Vout (Max) (V) |
Iout (Max) (A) |
Regulated Outputs (#) |
Switching Frequency (Min) (kHz) |
Switching Frequency (Max) (kHz) |
Iq (Typ) (mA) |
Features |
Control Mode |
Duty Cycle (Max) (%) |
Operating Temperature Range (C) |
Rating |
Package Group |
LM3102 | LM21305 | LM3100 | LM3102-Q1 | LM3103 |
4.5 | 3 | 4.5 | 4.5 | 4.5 |
42 | 18 | 36 | 42 | 42 |
0.8 | 0.6 | 0.8 | 0.8 | 0.6 |
7 | 0.6 | 7 | 7 | 7 |
2.5 | 5 | 1.5 | 2.5 | 0.75 |
1 | 1 | 1 | 1 | 1 |
200 | 300 | 200 | 200 | 200 |
1000 | 1500 | 1000 | 1000 | 1000 |
1 | 9 | 1 | 1 | 1 |
Enable Synchronous Rectification Tracking | Enable Frequency Synchronization Power Good Pre-Bias Start-Up Synchronous Rectification | Enable Synchronous Rectification Tracking | Enable Synchronous Rectification | Enable Synchronous Rectification Tracking |
COT with emulated ripple | Current Mode | COT with emulated ripple | COT with emulated ripple | COT with emulated ripple |
94 | 100 | 94 | 94 | 94 |
-40 to 125 | -40 to 85 | -40 to 125 | -40 to 125 | -40 to 125 |
Catalog | Catalog | Catalog | Automotive | Catalog |
DSBGA HTSSOP | WQFN | HTSSOP | HTSSOP | HTSSOP |
型号:LM3102MHX/NOPB 封装:HTSSOP-20_6.5X4.4MM-EP
品牌:TI 描述:是降压型-40℃~+125℃@(TJ)1降压可调0.8V~7V 4.5V~42V 2.5A 1MHz HTSSOP-20-EP DC-DC转换器ROHS
金额:¥13.20000
去购买
